having trouble with boiler, 0 psi
Repair man charged to look at it and said it is a big problem, did not offer any possible simple solutions. If the expansion tank reads 0 could that cause a loss in psi for the boiler?
The DeWalt 4.5 in. — 5 in. grinder has variable speed control (six speed settings), a safety system that shuts down the tool if the blade binds, and a brake that stops the wheel after the trigger is released.
Maybe?
I'm not an expert, but have a basic working knowledge:
So far as I know the systems are generally air free closed sytems, and the expansion tank is there to contain the expanison of the fluid as the system heats up, and expands. It can also function as an air trap for any minor amounts of air that are trapped in the system.
So, if the system is cold, there probably shouldn't be any pressure.
Depends on the style of expansion tank. As a general rule, you should have a minimum of 12 psi in the system. A failed expansion tank will not usually cause a loss of pressure in the boiler. You really need to get a comptent tech to look at the system.
BTW, I do know systems.
He charged you to look at it, said it was a "big problem", and didn't tell you what was wrong???
The original company sent out another tech., and within a hour we have heat. Thank you Dave for an informative, and comprehensive fix.
Heat is good!!
I also have a boiler for heating source. Majority of the heating contractors in my area are "scoarched air" or just plain plumbers, If you found a tech that can service your system, hang on to him.
Make em a batch of cookies!!!!
