Anybody seen or remember reading a “Tips & Techniques” (I think) tip on insulated headers. I have been losing it trying to find it.
The design I’m looking for had 2 LVL side members, 3/4″ ply top & bottom plates and a rigid foam core. Not a prefab model – site built.
Anyone ever designed something like this ? Comments ?
I need to find the picture / story to show my boss.
Deezel
Deezel
Insulated headers for cold climates
The drawing shows the header that I've been assembling to solve both of these problems. It's essentially a box beam with plywood tops and bottoms, and sides made out of either 2x or, my favorite, laminated lumber. The result is a header precisely the same dimension as the wall and a continuous void the length of the header for insulation.
My engineer had no problems with the structural capability of this design. The key is to provide adequate nailing through the plywood into the sides. For these headers, I used 8d nails spaced on the same centers as the perimeter nails in our plywood wall sheathing. The results were the absolutely most perfect, easiest-to-work-with headers I have ever seen.
Bill Welch, Jackson, WY
Thanks Rich !
Now I can stop searching ! :)
Deezel
Deezel
BT to the rescue again.
I was just messing around over the noon hour.
BT is like a hundred eyes all looking out for ya.
Rich
I couldn't agree more. Where did you see it last ? I assume I was reading a re-printed article. I definitely havn't seen any 1998 FHB's.
ps - you also saved my co-worker who had also picked up the scent
Deezel
For $20, if you are a subscriber, you can access the FHB site and look up any old article.
Can be useful or frustrating.
Rich
cargin... we build insulated box headers for spans up to 8'
this is allowed and spec'd in the IRC code
for 2x4 walls we use 2x3 plus 1/2" ply in and out
we either install foam in the cavity or we drill the header skin and blow cellulose in
the two sizes listed are 9" depth and 15" depth and the allowed spans depend on the width of the house ( from 24' to 32' )
as long as we stick to the code we don't have to get engineering when we use these headers
for greater spans, if we wanted to use your design , we'd have to have engineering
to get around that , i just have our lumber yard spec the lvl we need and give me a print out for the BIMike Smith Rhode Island : Design / Build / Repair / Restore
Mike
Not my design.
I was just fooling around over noon hour, when I saw the OP request and I thought I would do a search on the FHB site.
Just to be clear. Do you rip a 2 x 4 to 2.5 ". One for the top and one for the bottom and then nail the 1/2" ply to the side?
Sounds easier to me.
I don't do much framing. So I can't advise someone on proper sizing.
Rich
well, you can rip some 2x....
but i just buy some 2x3 studs .. the max span is 8' , so the longest i'd need would be a 10' stud ( 8'-3" header )
90% of our headers will be under the 8' limit so we use quite a few of these insulated box headers
edit:
BTW... if the wall is 2x6 , then you use 2x4 + the (2) pcs of 1/2 ply brings the header out to flush
Edited 2/25/2008 4:20 pm ET by MikeSmith
Mike
2 x 3s are not part of the inventory out here.
That threw me for a loop.
Rich
isn't that strange ?...
i thought every area carried 2x3 for partitions
lot's of walls have no need to be 2x4... so space minded designers have spec'd them in lot's of situations
sometimes if we need an inch, we'll use 2x3
oh well, just another example of regional differencesMike Smith Rhode Island : Design / Build / Repair / Restore
mike, up here the regular lumber yards don't stock, but the big boxs do
isn't that funny...
i would have thought that universally, the tract builders would have 2x3 partitions where ever they could
it's one of those things where they can save money without compromising the quality ... not all partitions need to be 2x4Mike Smith Rhode Island : Design / Build / Repair / Restore
2 X 3's readily available around here, but NEVER spec'd.
Course, the quality of them in these parts is truly substandard. I doubt I could find a dozen, solid , straight pieces in one trip to the yard.
Mostly used for on the flat furring round here.
Beware the bikini clad female.
She may be interpreted as offensive.
saw 2x3s at the despot the other day and wondered what they were used for. Maybe they use 'em in trailers around here but haven't seen them in a house.
You can build much lighter box beams from 2x and CDX:
http://www.apawood.org/pdfs/managed/Z416.pdf?CFID=6909442&CFTOKEN=31910354
Solar & Super-Insulated Healthy Homes
