Header size is enough?
gh2 | Posted in General Discussion on July 31, 2011 07:40am
I have a 100 year old home and I have installed a header in a load bearing wall between between my kitchen and dining room. There is an existing 2-2″x4″ (true 2″ thick by 4″ thick doubled up) that i attached a 2-2×8 (with a 1″ board in between them). I figured that the 4×4 and 2 2×8 will be as good as 2 2x12s. The unsupported length (opening) is 7 ft. The home has a second story (bedrooms) and attic above the second story. Is this header system strong enough?
  1. Piffin | Jul 31, 2011 08:07am | #1
    Well, it depends....
    The combination you have is not as strong as a solid but probably will do the job.
    But the disclaimer is that there is no way to se what and how the upper loads are on this.
    1. gh2 | Jul 31, 2011 09:00am | #2
      Thanks for the response. To give you a little more info.. The house is 23 ft wide (center hall colonial) and the section im working on is 12 ft wide. Above this section of the house is a bedroom, a bath and above that is an attic. Hope this helps
    2. gh2 | Jul 31, 2011 09:00am | #3
  2. DanH | Jul 31, 2011 10:16am | #4
    So long as the bathroom isn't above it that's probably strong enough.
