Heat Barrier under comp shingles
JayTX | Posted in Energy, Heating & Insulation on June 29, 2009 08:49am
I have used the foil backed OSB on quite a few jobs when I have had to replace or add decking to a roof.
What is available when I only have to replace the shingles?
I have heard both sides of the issue of installing an aluminum backed heat barrier (http://heatbarriersystemsinc.com) on top of felt or decking and under comp shingles when reroofing a home. Does anyone have first hand experience doing this?
    BillHartmann | Jun 30, 2009 01:02am | #1
    The term "heat barrier" is not very meaningful.
    To my mind that term would be applied to something that blocks the conduction of heat. Metal foils are a very good heat conductor.
    But metallic foils high reflective and low emissive to radiant energy. That thus used for radiant energy (which you get a lot from the sun) barrier.
    However a radiant barrier needs to have the at least one surface of the metalic foil face a 3/4", or more, air space.
    The only way that you could had it above a roof deck would be to add sleepers and then put a 2nd deck on top of that.
