heat/insulate concrete slab on grade in New England
user-4090279 | Posted in General Discussion on March 8, 2016 02:14am
I have a concrete slab on grade (24′ by 28′).  The slab is not insulated.  I live in NH.  I have hot water baseboard heat.  I don’t want the expense of putting in a radiant floor that requires me to update my 1989 boiler.  Any recommendations?  The floor is freezing in the winter.  Currently it is covered with 3/4″ plywood and 1/2″ oak floor.
    spclark | Mar 09, 2016 09:31am | #1
    Only Recourse...
    ... I can contemplate then is trenching around your slab's perimeter so you can add some kind of insulation between the outside and what's next to / underneath your slab right now.
    Objective is to slow heat loss from slab; without ripping up that oak & plywood, you're left with doing something to the other (hidden) side.
    What's the soil like around your place? Any porch / sidewalk / deck / driveway limit getting right up to your slab? Any / all of which would reduce the effectiveness of what you could accomplish out there.
    deadnuts | Mar 09, 2016 10:38pm | #2
    Carpet. The padding and carpet will provide some insualtion value and it can reduce heat loss through your body via conduction due to the fact that fibers reduce surface contact.
Grout-Free Shower Panels
