?: Heat pump condenser fan wiring
edwardh1 | Posted in Energy, Heating & Insulation on December 15, 2003 07:39am
3 1/2 ton heat pump Original old condenser fan motor still running but starting to make bearing noises. I will oil it to see if it can go a little longer.
i have a same brand same size same rotation but a many years newer fan motor off a much newer unit that was replaced on my street.
Old fan wires – black, red, two kinda oranges wires (same color)
new fan mpotor – black red, one kinda brown wire.
Anywhere on web this is explained?
i thing black and reds are the hots (i will look inside the unit) but why different numbers of the other color? and why would it have two of the same color on the old motor?
  1. DaveRicheson | Dec 15, 2003 10:16pm | #1
    Can you read a wiring schematic?
    There should be a schematic on the inside of the compressor compartment access panel, or with the original installation papers.
    If you can't trace out the original wiring or read the schematic, call a pro. It will save you money in the end.
    Dave
  2. bake | Dec 15, 2003 11:22pm | #2
    Better start checking name plates, to make sure the voltage, phase and amperages all line up. After that I would look at the manufactures website.
    bake
  3. junkhound | Dec 16, 2003 04:01am | #3
    DIY advise:  Look/trace to see where the existing wires go (120, 240 neutral, ground???). Could be the old motor is 4 and 6 pole wound as a 2 speed, then you will be limited to one speed with the new motor.
    Then take your new motor and try it with different wire connections on 120/240, etc and see how it runs.  That's what I do.....  Hint: do the 120 test first, helps forthe breaker to be nearby. You can also take the end bell off the new motor to see which wire or winding the wire goes to, but ya gotta have a little clue how a motor works to do that, being you asked the question like you did, you likely don't want to try that.
    Then, hook the new motor into the circuit the way it ran best.
    2nd hint, if you don't have a clue if it is running correctly or not, go with the pro advice.
  4. ClaysWorld | Dec 21, 2003 06:31am | #4
    scrape the kinda brown wire and see if it's kinda white?
    scrape the kinda orange and see if they are kinda white?
     what are the two orange wires hooked up to now in the original?
     Clay
    1. edwardh1 | Dec 21, 2003 07:52am | #5
      thanks
      old motor has two hots and two wires to the run capicator. i got a new motor that fits fine with these wires,
      thanks.
      old 3 wire motor i did not use, but there is a way i think.
      thanks to all
Choosing a Paintbrush
  • The New Old Colonial
