heating question
hoto | Posted in Energy, Heating & Insulation on March 20, 2006 07:57am
Background; floors,walls,roof completed, 2 story, 3,000 sqf, icf construction, daylight basement with slab floor, will have low-e windows,
large windows/doors facing south in great room.
Question: If pellet/oil/? stove is placed in great room, is it feasible
to pull heated air from top of 25ft peaked ceiling and distribute throughout the house.
  1. Frankie | Mar 20, 2006 08:08pm | #1
    Sure. Isn't that what ceiling fans basically do?
    How do you intend to move the heated air into and through ducts?
    I have thought of using this idea within the cathedraled living room. Instead of moving the hot air down through ducts I thought of moving the cold air, low in the room, up to the ceiling.
    Frankie
    There he goes—one of God's own prototypes—a high powered mutant of some kind never even considered for mass production. Too weird to live and too rare to die.
    —Hunter S. Thompson
    from Fear And Loathing In Las Vegas
    1. pickings | Mar 20, 2006 11:42pm | #2
      Would the cold air then not fall and create a cold down-draft in the room.
      Would it not be better to pump the warm air to the floor level then release it, therby creating a warm up-draft?
      1. Frankie | Mar 20, 2006 11:53pm | #3
        I would rather keep the turbulence up high than down below where there is more dust to get stirred up.I think the cold and hot would mix well enough so that one would not feel the extreems as they would if the hot air was released low.I guess it also depends on the air velocity and direction when exiting the duct. My thinking is to have the cold air released from the gable ends. This would give it opportunity to mix well with the hotter air.Just some thoughts.FrankieThere he goes—one of God's own prototypes—a high powered mutant of some kind never even considered for mass production. Too weird to live and too rare to die.—Hunter S. Thompson
        Edited 3/20/2006 7:06 pm ET by Frankie
