I have a question on fitting fascia boards with birdsmouths.I have gable ends with 6×8 corbels coming out 4 feet and my barge /fly rafters are 4×10 23 ft.I have a ridge and two lower corbels to fit.I think I will cut birdsmouths in plywood fit seperate pieces tack against the gable end then screw them together with lapped plywood so I have a continuous piece, take down and scribe onto the 4×10 .Should I make the template fit the crown of the 4×10 first so height above plate stays correct.or is there a better way to fit these one shot fits.Hopefully its clear maybe not .Thanks in advance Pell
As the industry phases out R-410A due to environmental regulations, new refrigerant options—R-32 and R-454B—offer lower global warming potential, but the best choice depends on your technician's training and familiarity with these newer systems.
Video: Build a Fireplace, Brick by BrickRelated Stories
http://www.quittintime.com/ View Image
Thanks see you Its clear now I just needed a little nudge
Pell
