Help darkening gray granite
mwaltcarp | Posted in General Discussion on August 16, 2008 09:31am
I just had light gray slab counters installed in a kitchen remodel. I have not sealed the stone yet.
The client likes the color of the stone when it is rubbed down with water, which darkens the surface. Of course, the color lightens back once the water evaporates.
My question is: Can anyone recommend a good sealer which will darken the surface when applied and remain that way once dry? I’m trying to find a sealer which will not leave a high gloss finish, just darken and seal.
I have some scrap pieces of stone leftover to test on. Any help will be greatly appreciated. Thanks!
  1. Danno | Aug 17, 2008 12:02am | #1
    Mineral oil?
      IMERC | Aug 17, 2008 04:36am | #4
      paint....
      1. Piffin | Aug 17, 2008 05:10am | #5
        Dark blue?
          IMERC | Aug 17, 2008 05:43am | #6
          that'll work...
  2. MikeHennessy | Aug 17, 2008 12:30am | #2
    Dunno about granite, but mineral oil is the traditional stuff used to darken soapstone. You need to apply it about every month for a year or so, and then anually for a while after that to keep it dark.
    Mike Hennessy
    Pittsburgh, PA
  3. USAnigel | Aug 17, 2008 02:24am | #3
    Had the same problem with slate. Used a water based varnish to seal/finish the tiles. Its on the floor in the main entrance to the house and its holding up very well but only been down 2 years. Try it on a scrap for color.
  4. WayneL5 | Aug 17, 2008 06:11am | #7
    Look into one of the stone enhancers on this page.  http://www.tecspecialty.com/content/products.aspx?sub_category_id=108
    I haven't use the enhancer, but I've use other products by Tec and have been very pleased.
    Jeff_Clarke | Aug 18, 2008 07:02am | #8
    Don't mess with it.  Seal and be done.
  6. mwaltcarp | Aug 19, 2008 12:07am | #9
    I Found the solution: a product from Aqua Mix called "enrich and seal". the stuff works great on my stone scraps. However, now I have a new problem.
    The corner area where the stone counter meets the stone backsplash had a bead of clear silcone caulk from the stone installers. I removed the caulk w/ a razor.
     I applied water to this area to see how the sealer will look. The stone does not absorb the water here. The result is a light stripe in the backsplah/counter intersection which is very noticable. The silicone caulk sealed the stone here.
    I've tried scrubbing the area w/ various stone cleaners, paint thinner, and torched it down w/ mapp gas. Nothing works, the stripe remains!!!!
    Any ideas on how to remove the silicone from the corner would be appreciated. THianks!
      BillHartmann | Aug 19, 2008 03:16am | #10
      I would try some Liftoff Silicon Caulk and Foam remover. If you can find it try some acetone or goof off.Let some set on the area for a couple of minutes and then wipe off.You might need to repeat it several times.And might need to make a poltice and use it to drawn out the last bits..
      Jeff_Clarke | Aug 19, 2008 05:58am | #11
      Acetone.   But it may take off what you just put down ... that's why I suggested 'let it be'
  7. Kowboy | Aug 19, 2008 05:59am | #12
    This is what you want:
    http://www.defusco.com/p2794/TENAX-UNIBLACK-STAIN-STEP-1/product_info.html
    Kowboy
  8. mwaltcarp | Aug 24, 2008 01:37am | #13
    Thnks all. I'm gonna try the acetone and goof-off. If those dont work I think i'll just "let it be" and apply some regular stone sealer.
    1. brownbagg | Aug 24, 2008 03:16am | #14
      a kid with a glass of kool aid will do it
  • A Grand Rescue on the Coast
