help finding a thread – posts in gravel
toledo | Posted in General Discussion on March 21, 2005 04:32am
can anyone direct me to a recent thread in which someone wrote about setting deck posts in gravel – I think without concrete –
anybody kinda remember…
maybe I was dreaming…
  1. calvin | Mar 21, 2005 04:41am | #1
     View Image Search Results
    138 messages found:
    Next 50View Image
    1. * Steve; We're almost done with our fence project that we ...
    - from Neena_Jud, 3/4/2002
    2. A common way is poured concrete. Down side is that that the ...
    - from 4LORN1, 10/17/2004
    3. Doug, it may be a moot point now given that I see from the date ...
    - from Jerrald_Hayes, 6/26/2002
    4. Fence Posts in Concrete or Tamped Gravel. Fence posts set in ...
    - from Hank, 5/25/2002
    5. If you want something with a bit more permanence, pour a 5- 6 ...
    - from Davo, 10/19/2003
    6. John, It's not the diameter of the foot. It's the diameter of ...
    - from Luka, 9/2/2002
    7. Pole Barn Repair. I've inherited a pole barn with problems, and ...
    - from Boss_Hog, 5/19/2003
    8. I think you got it pretty much right. I have never seen a deck ...
    9. best footing for pole barn posts * I saw a post regarding the ...
    - from Guest, 9/22/2000
    10. * Wayne, The key to a good job is in the base work. Above posts ...
    - from bearmon, 4/8/1999
    11. Deck questions. Will be building a 14' X 31' square-deck in a ...
    - from Derek, 2/21/2005
    12. You replied: Thanks for your interest. The site is in Maryland, ...
    - from Hasbeen, 7/21/2004
    13. Fence posts: set in gravel, dirt or c... * Installing a very ...
    - from Noel_Gaines, 3/24/2001
    14. * Most CCA 4" x 4" posts are .40 (rated for ground contact). ...
    - from James_DuHamel, 3/21/2001
    15. * Gentlemen, I have given some serious thought to all of this, ...
    - from Guest, 1/20/2000
    16. You don't say how many concrete posts you'd have to pour so I ...
    - from Dinosaur, 2/19/2005
    17. Fence Posts. I am getting ready to replace a rotten wood fence ...
    - from stan, 11/22/2004
    18. patio roof advice. Hi All, This is my first post to Breaktime. ...
    - from Chuck, 6/10/2004
    19. Do yourself a favor and use pressure treated 4x4's otherwise ...
    - from astro, 9/26/2003
    20. Timber Retaining Wall. I need to replace a crumbling stone ...
    - from Bart, 5/13/2003
    21. installing fence posts in New Jersey. I have to put in about 24 ...
    - from big_bob, 8/30/2002
    22. * The gravel attracting water theory is a problem solely based ...
    - from Mike_Willms, 3/18/2001
    23. * Ann, Your problem of course, is not whether to use a ledger ...
    - from G.LaLonde, 2/24/2001
    24. * Rein, I've been involved with floating slabs that were 45 ...
    - from Davo, 1/3/2001
    25. * dr I am going to start a custom built home on the river here ...
    - from Guest, 9/21/2000
    26. * Not a bad thought. It just dawned on me that permanent wood ...
    27. Some pole barn construction questions. I am planning on putting ...
    - from drptop70ss, 3/30/2002
    28. Fence posts don't need any concrete, according to me. Where I ...
    - from BReese, 3/29/2002
    29. * "...and lots of cement". Only if you are using steel posts. ...
    - from TJM, 2/26/2002
    30. PS: to answer your question directly about 4 posts, there is no ...
    - from DIRISHINME, 3/19/2005
    31. Advantages of gravel: * Promotes drainage. * May resist lateral ...
    - from Uncle_Dunc, 2/19/2005
    32. This is one of those questions where you'll get a hundred ...
    - from Dan, 7/15/2004
    33. Don't know where you are but we set all posts on barns/sheds in ...
    - from Ruby, 5/22/2004
    34. Mike-- Most wood posts I've ever seen buried have bit the big ...
    - from Dinosaur, 6/27/2003
    35. Question about sinking fence posts. I am putting in a pressure ...
    - from Bull, 12/28/2002
    36. Hi, sorry about the delay, I had to fly down to Southern ...
    - from johnbo, 9/6/2002
    37. Here is what my friend did with his workshop - Dig holes for the ...
    - from Ahneedhelp, 8/5/2002
    38. Setting fence posts in sewer pipe * I am going to put in a new ...
    - from Jim_Nation, 4/17/2001
    39. * Gravel will certainly invite water into each hole similar in ...
    - from Pete_Draganic, 3/18/2001
    40. * Twenty years of dock building and now several years of tennis ...
    - from Guest, 1/21/2000
    41. * Lots of options -- since you mentioned concreting the posts ...
    - from Guest, 7/15/1999
    42. Our specs call for twice the footings. 14 for that size atop ...
    - from Lawrence, 2/21/2005
    43. Adding a porch - fndtn and planking. I'm building my own home. ...
    - from Earthscaper, 1/28/2005
    44. Dek blocks will work fine - drop them on a 6" bed of compacted ...
    - from Mac, 1/27/2005
    45. I've set a fair number of posts in concrete, and am not adverse ...
    - from Mongo, 11/14/2004
    46. OK - assuming footers won't spark much interest, let's move on ...
    - from DIRISHINME, 8/2/2004
    47. "My feeling is that gravel allows drainage around the posts and ...
    - from Bill_Hartmann, 7/15/2004
    48. Frost jacking would be minimized if you have no fines (clay or ...
    - from David_Thomas, 7/15/2004
    49. pole buildings. i have had ongoing conversations with other ...
    - from moonmlns, 5/22/2004
    50. Set posts ON concrete with sompson hardware but never set posts ...
    - from piffin, 5/16/2004
    Next 50View Image
    Change search criteria?
    Quittin' Time
    1. toledo | Mar 21, 2005 07:07am | #2
      gracias - it was #11, I just missed it when I searched the archives...
    2. rez | Mar 21, 2005 07:21am | #3
      Calvin, you're hilarious! Roar!
      1. calvin | Mar 21, 2005 01:15pm | #4
        rezamundo, advanced search does it again.Remodeling Contractor just outside the Glass City.
        Quittin' Time
        1. rez | Mar 21, 2005 02:57pm | #5
          calvinator-
          In this instance EZ search would provide the same thing.
          be searched
          1. calvin | Mar 21, 2005 03:39pm | #6
            rez,  on a recent job I found and disposed of an old incinerator.  Managed to pry off the metal label>Calcinator.  Now graces the Dashboard, along with the rest of the debris.Remodeling Contractor just outside the Glass City.
            Quittin' Time
