Help! House we just bought came with a bad well!
1110d | Posted in General Discussion on September 5, 2012 09:55am
So, we just purchased a house that had been vacant for a while while the family settled the estate.  Closed less than a month ago, but have yet to move in because of some remodeling.  The former owner had been shunned by the family so they don’t have an intimate knowledge of the current property condition and it’s issues.  Prior to closing, the well and septic system were tested and inspected.  Per the summary letter, “The bacteriological analysis of the water sample indicated no evidence of bacteria contamination.”  However, under comments and recommendations he wrote, “Water very black from iron oxide buildup.  Recommend chlorinate and flush well.”  Last night the water turned coal black and it stinks.  Initially I thought it was just it was just sediment, until I tried to pull a sample from the tank.  That sample was also black and had bits of debris in the water.  The debris looked like rotten leaves and left a greasy mark when rubbed.  I’m told that this is an indicator of iron bacteria.  From what I’ve read on iron bacteria, the problem is all but impossible to permanently solve.  Sounds like this will need continuous maintenance and will have to be disclosed when we sell the place.  Needless to say, we’re very unhappy right now.  I’m not the sue happy type of guy and right now just want to focus on getting good quality water.  I also have to figure on where to get the money to pay for the need.  Thoughts????  Does the title insurance cover this?  Homeowners?  Can we drive the casing deeper to get into a different aquifer or does the well need to be abandoned?  It’s a newer well, so I presume it was contaminated when the well was drilled.  Is the aquifer contaminated near the well, such that we have to move it a long distance away?
File format
  1. davidmeiland | Sep 05, 2012 10:24am | #1
    Probably want to
    talk to a local well driller first.
    1. 1110d | Sep 05, 2012 10:27am | #2
      Already scheduled...
  2. DanH | Sep 05, 2012 10:58am | #3
    Yep, a local well driller or pump guy will know what local conditions are and how to deal with them, whether it involves revising the well somehow or just cleaning it.
    But keep in mind that any well that's unused for a long period will go sour.  The first thing you should do is simply run a few thousand gallons out of the well to clear out the stagnant water.
  3. Piffin | Sep 18, 2012 08:23pm | #4
    First
    Run the water for a few hours.
    That night drop a few pool shock tablets down the well. Then spill a gallon of Chlorox down.
    Next AM, Start runnig the water again thru all faucets and spigots. After a while - say 20-30 min - close all but one and let it run untill the chlorine smell is gone. By that time, the black should be gone too. If prolem still, conmtact a driller or treatment company
    This is most likely due to absence of regular use and f;lushing  the system will solve the problem.
Rescuing Old Hardware
Whether it’s already in your house or picked up at a flea market, vintage hardware almost always needs help.
