Help in adding Rigid insulation too h…
| Posted in General Discussion on May 4, 2001 05:21am
I want to add Rigid Foam insulation to the exterior of my house when i build it. i know i will have to frame out with 2×2’s around the windows.
What i want to know is what kind of Insulation do u recommend?? should i add Tyvex after its installed too??
would it make it harder to install the siding after the rigid insulation is installed.
thanks
  1. jon_ledebuhr | May 04, 2001 05:21am | #1
    I want to add Rigid Foam insulation to the exterior of my house when i build it. i know i will have to frame out with 2x2's around the windows.
    thanks
