Help. need short baseboard diffusers
bcsmith | Posted in Energy, Heating & Insulation on May 16, 2003 01:22am
I need some baseboard diffuser vents that have an outside height of no more than 3 and 3/4 inches (why do they make these things so dang tall?).  Did something stupid.  Thought my base was taller than it actually was and I was going to face mount them on the flat portion of the base.  Needless to say If I don’t find some, I need to do some very painful base removal or try to chisel to get them recessed into the base.  Neither appeals to me much.
I’ve called everywhere I can think of, and searched the net.  If noone knows where I can buy some, does anyone know where I can have some made?  Need white.
Thanks in advance,
Bill
  1. skids | May 16, 2003 01:44am | #1
    why don't you try cutting a standard diffuser down to the right dimension and then trimming them out? also if you can borrow a plasma arc cutter that may be the ticket, very little slag and a nice straight edge, may not require trim
    1. bcsmith | May 16, 2003 01:56am | #2
      I'm not much of a metalworker and I'm not sure about painting the finished product.  I thought about cutting with a snip but realized how it would look.  Mebbe I could take one to a smithy and see what he thinks.  What would you paint it with?  I thought they had some sort of powder coated finish, no?
      Thanks!
  2. nigelUsa | May 16, 2003 02:05am | #3
    get the floor model and drill holes to mount in place. I often use these in the toe kicks of cabinets.
    1. bcsmith | May 16, 2003 02:30am | #4
      The hole in the floor extends from the front of the base outwards about an inch and a half.  The only way I could use floor registers (as I see it) is to cut metal again, or move the holes in the floor.
      Thanks,
      Bill
      1. nigelUsa | May 16, 2003 05:26am | #5
        try this link http://doityourself.com/store/wallregisters.htm you might find what you are looking for.
FHB Podcast Segment: Embodied Greenhouse Gas Emissions and the Building Codes
