I am renovating a family room which currently has knotty pine in 10″ widths. When finished I will probably have 75 or so 7′ planks. Is there an aftermarket for this or should I just scrap it?
The code requires installing an approved material to slow the spread of fire between floors and adjacent vertical and horizontal cavities — here are the allowed materials and required locations.
Maybe, See if there is a bulletin board in your local lumberyard you can put a notice on.
"The first rule is to keep an untroubled spirit. The second is to look things in the face and know them for what they are." --Marcus Aurelius
or try ebay
bobl Volo Non Voleo Joe's cheat sheet
I would think someone somewhere would have a use for it, if your looking to make money off it try an add in the paper or post it here, if you just dont want it to go to waste and not concerned so much on making money off it, you could try small to mid size cabinet and furniture shops or local craftsmem, not sure if they would buy it or want it but I have seen some beautiful furniture made out of salvaged lumber. One last suggestion if you have a store like the woodworkers store or woodcraft you could call and see if they know of anyone that might be interested.
