I wanted to know if this idea will work. I’m trying to find a suitable place to install a stacked washer and dryer and I was thinking about removing the bathtub, which is used as a shower 99% of the time, and then using the freed up space to install a stacked washer/dryer. can I use the same drain as the shower? I will be building a partition wall between the shower and the W/D. Can I use this wall to place the power outlet being that the shower will be on the other side of it?
Any help and advice appreciated,
Mike
Whether it’s already in your house or picked up at a flea market, vintage hardware almost always needs help.
Seems do-able from a construction & plumbing standpoint, but I sure wouldn't want my laundry room part of my bathroom......
Thanks,
No it won't be part of the bathroom. I'll just be using the partition wall for the back wall of the enclosure for the W/D. The actual access for the W/D would be from the hallway outside of the bathroom.
Mike
It's pretty commonly done in apartments here.
I don't know what you're facing in terms of existing site conditions, but once you get the tub out you'll have access to easily remove as much subfloor as you need to for plumbing the drains and supplies for shower and washer.
"Let's get crack-a-lackin" --- Adam Carolla
Don't know where you're located, but check your plumbing code for drain pipe sizing. Here in WI most bathtubs have 1 1/2" drains, but the code for a shower requires a 2" drain. Once installed that 2" would be large enough to handle both the shower and the clothes washer.
"Here in WI most bathtubs have 1 1/2" drains, but the code for a shower requires a 2""do you have any idea why? lots of tubs here have showers too, so the amount of water going down the same. afraid of backups in the shower?
bobl Volo, non valeo
Baloney detecter
Yes, it has to do with backups. If a tub backs up, it will hold a lot more water before it overflows giving you adequate time to discover it. With a shower, it doesn't take much water backing up before it overflows the curb.
Are you talking about a standard 5 foot tub?
I'll answer that question, yes he is talking about standard 5 ft. tub.
How do you know?
My bad, I thought the question pertained to what is a standard size tub. Looks like more beer is the only answer!
If it is a standard 5 foot tub that is not going to leave much space for a shower if you lose 2' 6" to teh washer/drier and 4+ inches to a partition wall. You end up with 2 feet 2 inches for the shower. Nice!
how many joists will be cut out?
Baloney detecter
Heck, just leave the tub there and build the partition down through the middle of it, with a small hole at the bottom edge so the water can drain. Set the W/D right on top of the tub and let the hose dangle into the tub. No replumbing required!
Don't forget the 220 sevice for the dryer....
From a resale point of view, replacing the tub with a shower makes that a 3/4 bath or a 1/2 bath and can lower the value of the home.
Not around here. If it's got a foot bath is counts as a "full" bath.
Probably depends on state regs, so always best to check before lowering your house value. I was going to replace the tub in the master with a same size walk in shower when I found this out and scrubbed the idea.1 - measure the board twice, 2 - cut it once, 3 - measure the space where it is supposed to go 4 - get a new board and go back to step 1
Pretty sure it just has to do with local real estate agency practices for counting stuff.
