Help sizing trimjoists for 20′ span
meecect | Posted in Construction Techniques on October 31, 2012 10:07am
Hi, I have a masonry garage with a 18ft high ceiling and would like to add another level inside (a second floor, in other words).  I’d like to use Trimjoists to do this and was wondering if I could get a sanity check on the depth I will need.
The width of the garage is 19’3″ from brick to brick.  I want to clear-span this.  Looking at the span tables from trimjoist ( http://www.trimjoist.com/spans.html), it looks like I could use j-12’s spaced 24″ on center to get a L/465 floor with a load of 40-10-10.
Frankly, this sounds ridiculous to me.  I made the mistake of spanning 20 feet before on another project with 12″ trimjoists and spaced them 19.2″ OC and have one hell of a bouncy floor.
So I was thinking of just bumping up to the J-14 and spacing at 19.2″.  According to their table, even with a 40-20-10 load and L/539 defelction, I should be able to span over 24′ with this setup, and I only have to go a bit over 19′.
Does this sound like a good plan?  Will it too be bouncy or is it overkill?  Truthfully, I can’t tell because those span tables look silly to me.  Is there something I’m missing?
Also, most of the joists will go all the way across the 19′ , but will be shorter where my stair well is.  Should I still get the same depth of joist for that section for the uniformity of ceiling height in the space below, or should I save a bit of money and get smaller depth joists over that section?
Thanks in advance,
Cliff
    BossHog | Nov 01, 2012 06:49pm | #1
    A long time ago I did a thread on floor vibration.  You can find it here:
    http://forums.finehomebuilding.com/breaktime/general-discussion/floor-vibration
    If I were to design floor trusses for that span they'd be 14" deep. So I think you're on the right track.
