Help with Foil covering
Dunc1 | Posted in General Discussion on May 27, 2009 06:18am
Not sure if “foil” is the proper name for the plastic film used on cupboard doors. Anyway, a corner has peeled back slightly – courtesy of a toaster.
Can re-application of gentle head – hairdryer on low – allow smoothing or will it only make it worse?
Assuming the above is the way to go is this material glued to the base material as well? What kind(s) of glue?
  1. rez | May 29, 2009 03:55pm | #1
    Greetings dunc,
    This post, in response to your question, will bump the thread through the 'recent discussion' listing again which will increase it's viewing.
    Perhaps it will catch someone's attention that can help you with advice.
    Cheers
    94969.19  In the beginning there was Breaktime...
    94969.1  Photo Gallery Table of Contents
    And now he could feel it- that inevitable craving for cookies! It happened every time he left his firewall down.          -Heck '02
  2. FastEddie | May 29, 2009 04:06pm | #2
    I believe it is called thermofoil.  never tried to fix it.  maybe a little contact cement?  Is it just curled back, or is it damaged?
    1. Dunc1 | May 30, 2009 04:30pm | #3
      Thanks for replying.Foil has curled back so it is short of covering the full surface. Tried gentle heat from the hairdryer - it softened the material & I smoothed it somewhat. Biggest problem now is it is short of complete coverage. I asked at HD & paint dept said bring in the door; color can be matched by computer. Bought a can of suitably tinted melamine paint. Will give it a go. Only good news is that the defect is barely visible when door is closed.
