Help with kitchen backsplash
trusche2 | Posted in General Discussion on August 28, 2022 05:16pm
Hi to Everyone – I am a retired homeowner who needs some suggestions for a DIY backsplash above the kitchen sink.  Here is the problem:  from the countertop there are two rows of tile (2″ wide, with the top covered with a thin strip of metal banding), then about a two inch section of exposed drywall which is followed by the MDF windowsill molding.  Because the exposed drywall tends to get wet with normal use of the sink, I need to cover the exposed section with something that’s waterproof.  I’m not sure what options are available, but I sure would appreciate your suggestions (plywood strip covered with acrylic paint? plastic strip glued to drywall?).  I don’t know how to set/cut tile and feel that any attempts to do so on my part would not not end well.  Thanks for your help.
JT
  1. calvin | Aug 28, 2022 09:43pm | #1
    Thickness of what that metal strip is will probably give you only a couple of options.
    A course of matching, bold opposite tile accent, color close/complementary solid surface or even a strip of mirror.
    Or, time to change it all.
    1. bing0328 | Aug 29, 2022 02:13pm | #2
      I second the change it all option. Nothing you add to what you have will look have as good as doing it over.
  2. mgmahan | Oct 05, 2022 01:32pm | #3
    FRP. Fiberglass reinforced panel. I had a similar situation above a laminate back splash. I used FRP to cover the drywall that needed a lot of work. It's easy to work with and comes with edge and corner treatments. I'm not sure if there are colors available other than white.
    1. calvin | Oct 05, 2022 09:33pm | #4
      Almond is another color
  3. Deleted | Oct 12, 2022 11:02pm | #5
    “[Deleted]”
  4. Deleted | Oct 13, 2022 05:26am | #6
    “[Deleted]”
