HELP WITH NEW EXTERIOR WALL AGAINST EXISTING DECK
andymusser | Posted in General Discussion on November 21, 2019 02:02pm
I would like to build an addition wall that will directly abut an existing deck rim joist.  The new wall will have vinyl siding.  The deck is high enough that the wall portion below it will need to be sided or otherwise protected from the elements, however, access below the deck is very limited.
I am open to suggestions on how to proceed.  If anyone could direct me to a drawing of a similar nature, that would be even better.
Thanks in advance for your help!
  1. mike_augustine | Nov 26, 2019 09:42am | #1
    Can you post a sketch drawing?
