Help with vertical wood siding and vented rain screen
gillhall | Posted in General Discussion on July 23, 2020 08:47am
Hi, I am interested in building a double stud  garage  / Second floor Mother in law suite.
To match existing buildings , I want to use T&G rough cut Spruce vertical cladding .
How does one make sure an adequate vented rain screen is properly designed with horizontal furring?
Thanks for your assistance .
Gill
  1. jlyda | Jul 23, 2020 09:25am | #1
    Install thin battens like 1/2” ply or similar on the vertical. Follow that with horizontal battens applied to the vertical to create a drain plane behind horizontal battens. Or install a rain screen fabric type of material w/ no battens.
    1. gillhall | Jul 23, 2020 12:10pm | #2
      Makes perfect sense . Thanks for you knowledgeable advice .
  2. Graceconstruction | Jul 23, 2020 02:15pm | #3
    We rip 2” strips of T-111 siding the 4’ way. Nail over WRB with the grooves against WRB. I wrap the top and bottom strips with insect screen. I use plywood around window and door openings under WRB. I can screw 6 sheets together and cut them with the track saw at one time.
    1. gillhall | Jul 24, 2020 09:03am | #4
      Thanks , that sounds good
    2. user-3976312 | Jul 25, 2020 11:04pm | #5
      Like it!
    tfarwell | Jul 26, 2020 04:11pm | #6
    I've done the T-1-11, using the kind with 4" OC groves. Worked really well. I was able to get it cheap by buying damaged sheets. You're going to cut into 2" strips anyway.
