I want to use the 1″ hexagonal mosaic tiles on my bathroom floor. However, I am having a very hard time finding photographs of different color and pattern combinations? Please help!
Thanks!
This spray-foam sealant from Great Stuff offers mess-free, 6-in. coverage.
American Olean made them last time I checked. Since they'll make up the patterns for you they had quite an extensive brochure of traditional patterns.
ShelleyinNM
Thanks so much. Actually, I had already found the product at a local flooring distributor, but they really don't have a good brochure. Tried the American Olean web site too, but no luck...
Any other thoughts?
B4 you give up, go to the local American Olean distributor or call their tech support line and ask.
As I said, they were into making up the patterns for you and had an extensive brochure. 'Course, they wanted an extra $4/sf to do that. I found it much more reasonable to buy the field tile, rip out the pattern that I chose, then lay the pattern in after the field tile set up.
If you still have no luck, you might check the John Bridge forum on JLConline. That's where the tile pros hang out. If anyone will know, they will.
Thanks for the great tips!
I second the recommendation for the American Olean brouchure. I've seen it in a tile store in my old community, and it was extensive.
They can even take a color photograph and electronically produce a wall size mosaic ready to install. But, their pattern diagrams are really good, too.
