hi speed corded drill with a brake
i am looking for a hi speed corded drill with a brake for drilling shelf pin holes, any feedback? thanks!
a brake?
a brake like on a cordless drill, stops the chuck immediatly
huh....and all this time I thought it was the gearing,but why do you need a brake? I recall seeing tappers on drill presses that ran backwards until the tapper had pressure on it....
Why not use a stop collar or the cheap way wrap a piece of tape around bit at proper depth and leave a little tail of tape. When the tail starts slinging dust time to stop.
they used to make a collar that attached to a drill bit. It had a set screw on the side. Move it up and down on the bit to control depth of hole drilled..++++++++++++++++
-Do the thing you fear and the death of fear is certain-
That would also be handy for pocket hole jigs! I'd also buy a corded drill with brake since a cordless that spins fast enough is usually a bit on the heavy side.
It's not a depth adjustment that he's looking for, it's a quick stopping bit to make moving the drill guide and reinserting the bit quicker.
Since I've never seen one the thought did cross my mind to simply rig a power cord to a cordless drill and run it off a DC power supply or even simply a remote battery.
Edited 2/25/2006 12:55 pm ET by IdahoDon
I have an old B&D drill that was called a scrudrill. It only turns when there is pressure on the chuck. Still works great.
A vix type bit is what he really needs, the bit is ensconced in the guide, and the guide don't spin..just leave the drill on like a sheetrock driver and plug away.
Or use a plunge router in the same fashion.
