I am going to buy one or the other next week.The local prices are PC $460, Bosch $380.(cdn).Nobody has any in stock so I can’t compare to see if the PC is alot more robust than than the Bosch or not. I have about 40 doors to hang, all doug fir stain grade. And likely more in the future .So I think thats enough of an excuse.
I tried a few searches in this forum but prospero seems to think that hinges have somthing to do with buried water lines and doors are just for electrical panels.
Any opinions/advice appreciated , enjoy the long weekend folks,
Thanks Rik
Do they still make the Milwaukee ? It may be less than the Bosch in your area.
Phill Giles
The Unionville Woodwright
Unionville, Ontario
I have the Bosch.
It can be set up to do 4 hinges and 7'0" doors. All metal and forgiving. The scales are accurate. Used it for years and thousands of doors latter, zero promblems. Simple and no options needed.
I use a small, slightly larger than a trimmer, 3/4 horse router, much easier. Not much power needed.
The Bosch has got it all over the PC...can't you mail order it with an overnight express?
http://www.amazon.com/exec/obidos/tg/detail/-/B0000224KW/qid=1050631396/sr=1-1/ref=sr_1_1_etk-tools/102-6021547-6295329?v=glance&s=hi&n=228013
Dang, send me the moola, I'll send to ya.
40 doors, whatever you get will be earning it's cost<G>
EliphIno!
Thanks I think I'll probably go with Bosch ,can't find a milwaukee. Workin on an idea to get a client to subsidize this purchase but it's gonna take a bit of fine tuning yet ; ) Any other comparable brands I should be lookin at ? Rik
NONE!
With only 40 doors to hang, that jig is going to cost you $10 per door. Where I'm from the price to hang a door is around $40. That jig is gonna cost you 1/4 of your profit. I hang about 40 doors a month with the heavy duty Bosch jig.
If I was only going to hang 40 doors I'd make a jig out of a 4"or 5" strip of 3/4" plywood. A plywood jig can easily be used for a couple of hundred doors. Find a door that has already been hinged and make a template that will duplicate those cuts using a 5/8" router bushing and a 1/2" router bit. A standard 3 1/2"hinge with a 1/4" radius is normally set 1 1/8" onto the door and jamb with spacings of 7" from the top 9" to 11" from the bottom and the middle hinge centered between the two.
If I had $400 to burn I'd spend it on couple of a new routers, I've been eyeballing that new Millwakee with the hand grip. A little bit heavy but that micro adjustment is sending shivers down my spine!
Turtleneck
Its not a smile- its a cramp
I suggest you think about just laying out the hinges and buying a Lie-Nielsen Butt Mortise plane for about 100bucks.
With this handplane there are no test cuts, powercords, router noise etc. Most would be surpised how effective it can be.
http://www.lie-nielsen.com/tool.html?id=40B&cart=10506741236132
wow, forty doors 3 hinges each, thats a lot of hand work!!
I have the Lie-Nielsen, the Bosch jig and a Hinge Mate. Our company has about 8 of the Bosch jigs and 1 Porter Cable. I looked at the Bosch and the PC side by side, used both, and bought the Bosch. No question a better unit. Not to mention that the Porter Cable case that holds the jig is the biggest, longest, most ridiculous thing you've ever seen. As far as the Lie-Nielsen, a fabulous tool that is suited for a door or two, maybe three at a time. 40 ? Forget it. Buy the Bosch. The Hinge Mate is also an effective product for doing custom hinging on doors going into existing jambs where the jambs are already cut. I had the Hinge Mate before the Lie-Nielsen. Ever since I got the Lie, I doubt that I ever used the Hinge Mate again. That hand plane is a pleasure to use. Do you have a planer to do your fitting ? We use PC 126's. Perfect door plane that has gotten damn expensive.
carpenter in transition
When I bought the Bosch last fall, I was told by the owner that they were not carrying this item any more because most doors were pre-hung. He gave me a nice deal and I was happy. But I was shocked at his statement about no one hanging doors separately any more!!
Big Bob
I got 35 hits "typing hinge" template from a big discussion we had a while ago if you're interested in more opinions.
Clampman
