Holding unfaced insulation to ceiling
housenut1 | Posted in Construction Techniques on April 2, 2007 04:19am
Any simple suggestions for holding unfaced insulation in the stud bays? I’ll  be covering it with drywall temporarily too.
  1. dovetail97128 | Apr 02, 2007 04:21pm | #1
    3-M spray on contact cement.
    1. housenut1 | Apr 03, 2007 06:31am | #4
      Thanks dovetaiI. I'll keep this in mind if I need to install it permanently.  This is a temporary fix I will be spraying in insulation.
  2. FHB Editor
    JFink | Apr 02, 2007 04:23pm | #2
    The same place that sold you the insulation should carry springy metal wires that span the gap between joists to hold the insulation in place. They are usually used on ceilings, so I'm not sure if you will find them in 16 o.c. for use in walls.
    EDIT: I just re-read your post...the thread title mentions "ceiling" but your question asks about studs...which is it?
    Justin Fink - FHB Editorial
    Your Friendly Neighborhood Remodelerator
    Edited 4/2/2007 9:28 am ET by JFink
    1. housenut1 | Apr 03, 2007 06:35am | #5
      Thanks Justin.  They are the ceiling joists.  I guess I called them studs because they are 2x4 joists.  Seventy plus year old house.
  3. Dave45 | Apr 02, 2007 04:33pm | #3
    I've had good luck stapling string to the joists every 2'-3'.  That hold the insulation in place and the rock goes right over the string.
    1. housenut1 | Apr 03, 2007 06:37am | #6
      Thanks Dave45.  Your tip is just what I needed.
