Hole Filling for Fiber Cement
KeylessChuck | Posted in Construction Techniques on June 28, 2009 09:14am
What is the best material to use for filling small wholes in Fiber Cement?
    Dam_inspector | Jun 28, 2009 09:20pm | #1
    Define small.
    1. KeylessChuck | Jun 28, 2009 10:30pm | #2
      Nail and screw holes.
      1. BoJangles | Jun 29, 2009 01:00am | #5
        121809.3 in reply to 121809.2
        Nail and screw holes. ??
        You really shouldn't have nail and screw holes in cement siding.  If you do, you are driving the nails in too deep.
        1. KeylessChuck | Jun 29, 2009 05:56am | #8
          The holes are from downspout brackets. I removed one of the down spouts from the house.
        Dam_inspector | Jun 29, 2009 01:12am | #6
        I use the quick dry exterior Spackle that comes in a tube for something like that.
  2. Scott | Jun 28, 2009 10:34pm | #3
    High quality paintable caulk, then paint.
    Scott.
  3. WayneL5 | Jun 28, 2009 11:00pm | #4
    Durham's Rock Hard Water Putty.  It won't shrink and show dimples like caulk will.  It must be thoroughly dry before painting, per the caution on the can.
    1. KeylessChuck | Jun 29, 2009 05:58am | #9
      Nice. That'll do it.
      Thank you sir.
      1. BoJangles | Jun 29, 2009 02:09pm | #10
        Oh....That sounds a lot better than what I was thinking!!
        I've never found a caulk that won't shrink.....so you can still see the holes.
          Dam_inspector | Jun 29, 2009 02:28pm | #11
          That's why I like spackle. If there is only a couple holes, I'd probably use whatever is at hand though. Glazing compound, bondo, epoxy putty, dowel plugs, setting type drywall compound, grout, etc will also work.
  4. TJK | Jun 29, 2009 05:09am | #7
    Lightweight exterior spackle works well for nail holes.
