Hole in top plate
Stan | Posted in Construction Techniques on June 3, 2009 10:51am
I am in the process of remodeling a spare bedroom in our house that was built in 1960.  As the room is down to the studs I figured I might as well bring some structrued cable into the room.  As I am in a time crunch and don’t have the time to figure out the phone, data, and video cabling I am just going to install 3/4″ flexiable plastic conduit into the wall and run it up into my attic.
Here is my question, the OD of the conduit is 1″ in diameter.  Will there be any integrity issues of the wall afer I drill the hole?  I was thinking of “sistering” a 2 x 6 on top with a 1″ hole also drilled into it.  Is this not neccessary or over kill?
Thanks!
“Projects beget projects and projects beget the need to buy new tools and that is what the cycle of life is all about.”
    Sphere | Jun 04, 2009 01:06am | #1
    No problem. I've seen top plates that look like swiss cheese above a panel box.
    "If Brains was lard, you couldn't grease much of a pan"
    Jed Clampitt
Eichlers Get an Upgrade
Performance improvements for the prized homes of an influential developer who wanted us all to be able to own one.
