I have a hole, 1″ round, in the vinyl siding on my house and would like to repair. I have some leftover siding from original install 18 years ago under the house. Any ideas on how to repair? Thanks
You can remove one pc (the hole pc) and replace with a new panel. You can find a vinyl siding removal tool (unclips the bottom lip from the lower pc) at most suppliers. Hang the replacement exactly where it was before and with the tool, or your hand slapping down on the siding, relock the panel.
You'll have to unlock the one above the damaged pc to remove the nails.
Quittin' Time
Yea - remove old piece, install new piece. May be better done on a warm day as vinyl siding can be brittle especially when cold and old. It's a bit of a trick to get off, but if you want to spend a few $ there is a simple tool that will help. I went to google for the tool and found this: http://www.hammerzone.com/archives/exterior/siding/repair/vinyl/panel/replace.htm
I have done this a zillion times----and I have a couple of those little tools floating around----------
but----if the siding is reasonably warm---not frozen----you can usually unzip it without the tool pretty easily.
start at a factory seam of the piece ABOVE the one you want to repair---slip your hand in behind and sharply pull down----that should unlock the corner----and you can then easily peel it down the length of the panel.
takes longer to type it than to do it.
for customersI have occasionally switched positions of an undamaged panel behind some bushes for a damaged panel more prominately located. Very handy trick for discontinued colors.
Stephen
Right - I know that - but if the guy had to ask the Q in the first place...
sorry---my remarks were not intentionally directed at you.
Stephen
No apology necessary. I bet you have to deal with all kinds of siding on a regular basis for situations when step flashings are behind there and nailed to the wall, etc. etc. From that perspective you are prabably the man for R&R of siding.
Also handy for faded colors.
If the siding has been stored under your house for 18 years, the color isn't going to match. So replacing a piece might not make sense.
Could you install a light fixture there, or otherwise hide the hole? That might look better than a mis-matched piece of siding.
A: Drool
If the hole is in a conspicuous place just use a piece from in back to replace it and put a new piece in the back.
