I have a situation where I need to get an 1-1/2″ pvc drain line through an I-beam. On the side of the beam that I need to put a drain is a concrete slab poured in to the web of the beam, on the other side are floor joists sitting on the flange of the beam were I need to tie into. Will it degrade the beam to put a hole through the web? Thanks for any help. -Ed
Listeners weigh in on Brian’s haunted showerhead and ask questions about covering overhangs with trim coil, sealing air leaks, and how to partially finish a basement.
SawStop's Portable Tablesaw is Bigger and Better Than BeforeRelated Stories
It sure could affect the beam, depending on the depth and size of the beam, where the supporting column is, the loads, and on and on. Sounds like the advice of a structural engineer is needed.
you is 100% right
So is you
Politics is the art of looking for trouble, finding it, misdiagnosing it and then misapplying the wrong remedies.
