Looking for the best way to hang a hollow core pre hung. Should I remove the door from the hinges and set the frame or install the unit as a hole. I won’t be attaching the casements prior to installation because I don’t have an air gun, ( just in case someone suggests that route).Also, what are the proper nails to use on the frame and on the casement? Every article I read suggests a different size nail. An answer to all these questions would greatly be appreciated. And remember, if you only answer in part you won’t get full credit. (ha!) Thanks all. Mick
![](https://images.finehomebuilding.com/app/uploads/2024/04/10100343/01232346-chimney-cricket-hdr-1-thumb-16x9.jpg)
Easy-to-make tools simplify the framing, while time-tested flashing techniques make it last a lifetime.
Looking for the best way to hang a hollow core pre hung. Should I remove the door from the hinges and set the frame or install the unit as a hole. I won't be attaching the casements prior to installation because I don't have an air gun, ( just in case someone suggests that route).Also, what are the proper nails to use on the frame and on the casement? Every article I read suggests a different size nail. An answer to all these questions would greatly be appreciated. And remember, if you only answer in part you won't get full credit. (ha!) Thanks all. Mick
