Any of you guys ever see something like this ?
It’s the residue left by a “tape that was used to repair a tear in the cherry veneer. I really didn’t notice it till I applied the stain. Then I thought I could just “tint” it out so I sprayed a sealer coat. This is what it looked like after the sealer coat a nice mess. . .
“The first step towards vice is to shroud innocent actions in mystery, and whoever likes to conceal something sooner or later has reason to conceal it.”
Aristotle
Joe,
Had something ssimilart about a month ago where I used blue painters mask on Limestone fireplace surrond to mask it off while I speayed the finish on the mantle and other woodwork. I was also working on other areas of the house so I didn't remove it right away. When I took it off about after three weeks, I had a darker shadow immediately under where the tape was.
Didn't worry because I assumed that it just lifted surface dust out of the limestone. But when I cleaned up the job after another couple weeks, it wouldn't wash out. I had to scrub it about a dozen times with weak acid wash to make it go away. My theory now is that it denied oxygen to the fresh limestone which was hardening and left the shadow which would have eventually evened out.
Lesson learned was to be careful about tape and remove it right away.
It doesn't take much, chemistry wise to mess up stains, glues, and finishes. I feel for you.
*Pif,
View Image"The first step towards vice is to shroud innocent actions in mystery, and whoever likes to conceal something sooner or later has reason to conceal it." Aristotle
*Pif,
*nice job, possibly "wane surgery?".....
*Joe- looks like you cleaned that up beautifully- I have had to deal with tape residue left on sheet goods, but they never hid from me- havn't seen it in my limited experience with veneer- gb
*Joe: Isnt that a row of stitches that they use to seam veneers together? I see a row of what looks like evenly spaced stich marks down the seam. I know of a guy in my area that had huge stacks of veneer of various species, that he would stitch together with a machine that glued, stitched and rolled the joint. It was practically invisible when done.
*Stan,
*Greg,
*That's a new one on me. I usually wipe down anything I'm staining with a compatible solvent and allow it to dry before staining though. Beautiful job on the repair, blends in nicely.
