Hot Air& AC to Spacepac/radiant baseboad
Rampside | Posted in Energy, Heating & Insulation on December 7, 2005 04:31am
I have a 1950’s split level Colonial(?), with HVAC Hot & AC system. I’ll be adding on a 2 car garage with an attached 12×12 room and 2, 2nd floor bedrooms. I had planned on a radiant heat system in accessable joist space and baseboards in the existing slab room. There would be 2 Spacepak systems, one for each floor. For quick heat the Spacepak would have hydronic coils.
Contractors I’ve spoken to insist that I keep the existing duct work, extend it, get a variable speed furnace and duct dampers to regulate the floors.Excerpts from some discussions: hot air is more efficient than hot water heat. That radiant systems are to slow to heat-up and that they run all the time to keep the water flowing, therefore less efficient than Hot air systems. That dry throats are caused by any system. I’ll need 2 boilers, one for the radiant, and one for the baseboard system. Spacepak leaks and is noiser than the other HI-V system.
Why change….
My furnace is on its’ last legs. The present duct work causes the ceiling in the basement to drop to 6′ 1″ in a 5′ X 18′ area. There’s lowered ceiling height in the slab area, where the duct runs to go upstairs, a 8′ X 12′ area.The 2nd floor never gets hot or cold enough. I’d like to eliminate the chimney to forgo a $1k repair. It will be easier to run pex than duct and I could heat my new garage slab. I’ll eventually save money on my Natural GAS heat because radiant is more efficient.
Have I spoken to the wrong contractors or am I missing something??
What is the forum opinion?
THANKS
  1. NRTRob | Dec 07, 2005 08:34pm | #1
    Your contractors are incorrect. Obviously I'm biased, and efficiency jumps are a sketchy way to promote radiant as the difference is different for every building, but there is no arguement for FHA being MORE efficient than radiant. Perhaps a well designed FHA vs a crappy radiant system.
    I would suggest making sure whatever you choose has outdoor reset control for maximum comfort and efficiency.
    -=Northeast Radiant Technology=-
    Radiant Design, Consultation, Parts Supply
    http://www.NRTradiant.com
    johnnyd | Dec 07, 2005 09:34pm | #2
    Rampside:
    To get better replies you'll need to supply a little more information like:
    Your location and average number of Heating Degree Days
    Rudimentary heat loss calculation in BTUs per hour or BTUs per sq ft per hour.  SWAG numbers could be had by multiplying 30 BTU/hr X sq ft of heated area for older residential, 17 BTU/hr for new residential
    Accessability of the floor joist spaces in your current structure
    Sounds like you haven't yet talked to a heating contractor that specializes in radiant floor heat.
    Edited 12/7/2005 1:37 pm ET by johnnyd
    Edited 12/7/2005 2:20 pm ET by johnnyd
Shoulder Your Buckets
Add a strap for easy carrying and pouring when working with 5-gal. buckets.
