Have a GFI circuit in the kitchen. Started the microwave and the circuit went kaput. Put the little tester in the outlet (and all others on the circuit) and it says the hot and ground are reversed. Further, when using a test light, both the hot and the neutral are hot. Replaced the GFI outlet, same result. Checked all the outlets and everything looks in order. HELP!
Choose the right WRB product and install it well, because if you're not keeping water out, nothing else matters.
Someplace upstream the neutral is open.
happy?
Edited 11/12/2005 1:46 pm by DanH
