Hot Tub Diagnosis
Huntdoctor | Posted in General Discussion on September 27, 2009 07:43am
I have a hot tub that was turned off all summer. When I tried to turn it on today it pops the breaker.
220V on 50AMP GFCI. When the breaker trips it kinda sticks and when I reset it it does not feel smooth.
I checked the pump motor and it turns easy and smooth. I checked the heater and it is not open or corroded. Checked all the wiring and all looks good.
Could the breaker be bad?
  1. fingersandtoes | Sep 27, 2009 08:48pm | #1
    Try disconnecting the ozonator and see if it still pops.
    1. Huntdoctor | Sep 27, 2009 09:15pm | #2
      Ozonator is disconnected.Had problem with that last year.Thanks
      1. fingersandtoes | Sep 27, 2009 09:26pm | #3
        Next best bet would be the breaker. Is the Gfi on the tub or the panel? If it's on the panel can you try the tub on another breaker to see if it still pops to avoid spending the $$ on a new one in case it isn't the problem?
        1. Huntdoctor | Sep 27, 2009 09:42pm | #4
          ya it's on the panel.Using diff breaker as test is good idea.Thank's
          1. Huntdoctor | Sep 27, 2009 10:46pm | #5
            Think I have it figured out.Disconnected 220V at hot tub panel and breaker still trips. Gonna pick up a new breaker.When I install it I will report.Thanks for the help.Russell
          2. fingersandtoes | Sep 28, 2009 01:36am | #12
            "Disconnected 220V at hot tub panel and breaker still trips. "Spounds like the problem, unless you have little mice chewing the cord in between.
          3. Huntdoctor | Sep 28, 2009 01:37am | #13
            New 50AMP GFCI breaker from HD - $80.00Installed and all seems to be working. I will let it run it's cycle and see what the temp is.If all is ok then it is drain, clean, new filter and refill.Looking forward to soaking and relaxing.Russell
          4. silver77 | Sep 28, 2009 01:58am | #14
            "Looking forward to soaking and relaxing."A buddy gave me his old hot tub...we recently hooked it up-wow-a little slice of heaven...I sat in there this morning and watched the leaves fall...sweet
          5. Huntdoctor | Sep 28, 2009 02:16am | #15
            Yep it's the life.I will be putting mine up for sale soon. We want a smaller tub with more jets.I will be using mine until it sells.Fall and winter are my favorite seasons for tub use.Russell
          6. fingersandtoes | Sep 28, 2009 02:58am | #16
            Fixed it. Great. I have developed a visceral hatred of hot tubs after working at a resort where all 24 cabins have them. The newer ones make trouble shooting more like computer repair than mechanics. I just can't relax around them now.
          7. Huntdoctor | Sep 28, 2009 03:09am | #17
            Yep! Up and running.Thanks for your help.Russell
          8. silver77 | Sep 28, 2009 05:01am | #18
            dumb question-we're new at this and just fire it up when we want to go in...no chemicals at allbut come winter-do you leave it on and let it cycle throughout the day? we waited a year to hook it up because it seemed so wasteful and now we're trying to figure out how to keep it as efficient as possible...my electrician figures it's .50 cents for every hour it runs.we're also looking at the solar heaters that install on the roof-any experience with that?right now it's one of my favorite spots on the planet...it's in our backyard with a view of the pond-pure peace and quiet-now this old farm feels like my camp!cheers,phil
          9. Huntdoctor | Sep 28, 2009 05:11am | #19
            We run ours on a timer 3 hours on 3 off. If the water temp drops to much it will come on automatically.During the winter ours may run us $30 - $40 a month. Insulate box as best you can and use a good tight cover when not in use.You should keep track of the water chemistry just like a pool. It can get very bad due to the heat and being covered.I do not have any experience with a solar heater.Russell
          10. silver77 | Sep 29, 2009 12:30am | #21
            I can handle 30-40 bucks a month...and I'll take your advice and use 2" foam around the outside...our cover is toast-we need a new one.we are watching the ph-so far so good...we hate clorine...have any experience with alternatives??thanks,phil
          11. Huntdoctor | Sep 29, 2009 01:05am | #23
            We use chlorine in our hot tub and pool. We used to use non chlorine products but went back to chlorine because of ease of use.We have friends that still use non chlorine products and like them but I do not know what they are using.A good cover is the most important part of insulating a closed tub. Ours is bad also. We will get a new one before the real cold weather hits. About $450.00, Ouch.
            Edited 9/28/2009 6:06 pm ET by Huntdoctor
          12. fingersandtoes | Sep 29, 2009 02:09am | #24
            $450 and the foam inside is open cell so it gets waterlogged and hard to lift. The lids are a huge scam - but what can you do.
          13. Huntdoctor | Sep 29, 2009 02:18am | #26
            I agree. We will be buying our 3rd one. Last about 4 years.Any ideas?Russell
          14. fingersandtoes | Sep 29, 2009 02:52am | #27
            No useful ones sorry. With the abuse they take at the resort some only last a year. We have looked at all sorts of alternatives like getting a surf board maker to come up with a hard shell design. One thing that does prolong the life is wrapping the new foam in another thicker (6 mil) layer of poly and sealing the joints. Not much you can do about the naugahyde breaking down though.
          15. DanH | Sep 29, 2009 02:53am | #28
            Make your own?
            As I stood before the gates I realized that I never want to be as certain about anything as were the people who built this place. --Rabbi Sheila Peltz, on her visit to Auschwitz
          16. fingersandtoes | Sep 29, 2009 03:00am | #29
            Put on your inventors twirly cap and think up a good way to make a cover. I'm stumped.
          17. silver77 | Sep 29, 2009 03:03am | #30
            I've heard you can order new vinyl covers by themselves-I've got 4" foam in very good shape and we're hoping to just order the cover.
          18. Huntdoctor | Sep 29, 2009 03:09am | #31
            I just need cover also.Let us know.Russell
          19. fingersandtoes | Sep 29, 2009 03:43am | #32
            Yes you can buy either or. Most of our tubs are Sundance, but we get replacement covers from a local maker that is $150 cheaper. It might be worth asking a hot tub dealer near you.
          20. Huntdoctor | Sep 29, 2009 05:15am | #33
            Just an idea.Cover the foam with an old water bed bladder. Then make cover with good tarp or old winter pool cover.What do ya think?Russell
          21. fingersandtoes | Sep 28, 2009 08:06am | #20
            Unfortunately, with hot tubs there is no half way. Once you start them, you have to keep them going with regular filtering and adjustment of the chemicals - or drain them. If you test your tub you will be surprised at how quickly the pH and chlorine levels get out of whack, and this can have very serious consequences.
          22. silver77 | Sep 29, 2009 12:32am | #22
            We're trying to keep the chemicals to an absolute minimum...but we do test the ph daily to keep on top of it.do you use bromide??thanks,phil
          23. fingersandtoes | Sep 29, 2009 02:18am | #25
            The resort uses bromine tablets in the floaty mushroom thing but chlorine when filling. Because the tubs are drained so often between guests, the ozonator and other maintenance treatments aren't as important. It is basically a start up treatment each time.
            A neighbour asked me to look at a tub he had bought six months before. I went over and the water had a green scum around the edges. I asked him which chemicals he was using and he replied: "What chemicals?". He then rolled up his shirt to show he his chest which was bright red up to a line near his neck and stunningly white above!
      2. alias | Sep 27, 2009 10:51pm | #6
        what the ozonator??
        1. Huntdoctor | Sep 27, 2009 11:03pm | #7
          Helps purify the water using ozone. Not really necessary but with one you might not use as much chlorine.Mine has not worked for several years and have had no water issues.
          Edited 9/27/2009 4:04 pm ET by Huntdoctor
          1. alias | Sep 27, 2009 11:15pm | #8
            'IS IT DONE WITH AN ELECTRICAL CHARGE??
          2. Huntdoctor | Sep 27, 2009 11:24pm | #9
            I think it is done with and ultraviolet light.Russell
          3. alias | Sep 27, 2009 11:35pm | #10
            yeah.. after i posted i remember seeing on i believe TOH, a ultra- violet light encased in tube where the water ran threw it. anyhow thanks for info....
          4. DanH | Sep 27, 2009 11:49pm | #11
            Same price as for the rest of the electricity.
A Practical Perfect Wall
  • The New Old Colonial
