hot water heater in crawl space
paul42 | Posted in General Discussion on December 5, 2006 08:19am
Due to the lay of the land, it appears that the house I will be building will have a pier and beam construction, and on one end of the house, there will be somewhere around 7 or 8 foot of head room in the crawl space.
The crawl space will not be vented, and will be part of the conditioned space.  With that kind of head room, I plan on a full size door for the entrance.
Would it make sense to pour a small slab and install the electric water heater in that space?
I’m also thinking that it will be a good spot to hang the central vacuum system.
Crazy ideas?  Not permitted by code?
  1. JohnSprung | Dec 05, 2006 09:09pm | #1
    Probably just fine, but the region you'll be using might better be termed a basement than a crawl space.  Having part basement and part crawl space is done all the time.
    -- J.S.
  2. dovetail97128 | Dec 05, 2006 09:53pm | #2
    I have done exactly what you are proposing, even hung the furnace in the space. Worked out great, easy access for all maintenance . Mine was gas heated application so we provided combustion air to code in a small room we framed for the appliances.
