House Leveling 3 story 125 years old
RoryMatthew | Posted in General Discussion on February 18, 2013 10:58am
I have a 28′ x 44′ 3 story home that needs leveling. The outside is a 3 course brick and appears that it has either settled evenly or has not settled. The 5 inside piers seem to have settled about 3 inches in the middle.  The beams are 4 2×12  spanning 8 feet and one section spans 10 feet.
  1. florida | Feb 19, 2013 07:48am | #1
    Sounds like a typical old row house. It can be jacked up, whether you're the one to do it is a different question. It didn't sag quickly and it can't be jacked back up quickly either. You'd need a heavy screw jack at each column and a lot of time. The last one I did took over a uear to get back level. We went by the house once a week and gave each jack a half turn. Didn't break anything but we lived on pins and needles for several years after we finished!
    1. DanH | Feb 19, 2013 08:08am | #2
      I've found that you can often jack a lot faster than one would think.  The limiting factor is generally that the wood has "taken a set" and if you jack too rapidly you can, eg, lift a beam off it's end supports while jacking in the middle.
FHB Podcast Segment: Embodied Greenhouse Gas Emissions and the Building Codes
