House wrap
| Posted in Construction Techniques on November 15, 2002 11:23am
I have a question. I’m getting ready to put my windows and doors in. And I was wondering, do I or, should I wrap the building with house wrap. I will be stuccoing it later. Around here (San Francisco bay area) They don’t house wrap that much. At least track homes. But should I wrap it? Before I put on my stucco paper and wire. Or should I not wrap and go with the stucco paper an wire. Thanks Hat
  1. royr | Nov 16, 2002 03:31am | #1
    Hat,
      I don't if you should wrap your house based on your area or not. but Tyvek does make a housewrap for Stucco houses, I think it comes in 4 foot rolls instead of the 9 foot Tyvek rolls. I would probably wrap my house if I were you as I've read on this board how stucco homes can absorb moisture over time...........Good luck
    Roy
    1. TimGoins | Nov 16, 2002 06:30am | #2
      Sounds good. But do I wrap before I put the windows in or after I put in windows or doors. Thanks Hat
  2. gordsco | Nov 16, 2002 09:07am | #3
    I don't like house wrap and I especially think it should not be considered in damp climates and especially where stucco is involved. Stick with the paper, its tried, tested and true. Staple 6" strips of paper around the rough opening before installing the window. Start at the bottom and then do the sides and top overlapping the pieces to shed water. After the windows are installed you can apply the stucco paper and wire.
    sometimes board sometimes knot
Outdoor Lighting
