What type of house wrap do you recommend? I’m in Texas. House will have OSB with Hardi outside. “Regular” insulation and sheetrock inside. Felt,Tyvek,etc.?
Any. Just install it so the upper layers lap the lower like shingles, and don't leave it in the sun too long.
Andy
"Never try to teach a pig to sing. It wastes your time and annoys the pig." Robert A. Heinlein (or maybe Mark Twain)
"Get off your dead #### and on your dying feet." Mom
"Everything not forbidden is compulsory." T.H. White, The Once and Future King
Thanks Andy. Do they make tape for felt, to seal the overlaps?
I wouldn't bother to tape either one. Taping is mainly done to minimize exterior air infiltration. Assuming that you sheathe with plywood or osb, not a lot of air is going to get past the sheathing. Actually, I'd probably go with ZipWall and skip the building paper entirely.Andy
It's amazing how much air can get past sheathing, but air infiltration isn't likely that big a deal in Texas.
Why is that. Ain't thar no wind in Texas?~ Ted W ~
Tool Auctions - MyToolbox.netSee my work - TedsCarpentry.com
Mostly hot air ... ;o)
Whoops ....
View ImageJeff
Edited 3/28/2009 10:29 pm ET by Jeff_Clarke
In Texas they don't have the common sense to shut the windows anyway, so it doesn't make any difference.
Why bother? It never rains there.
Oh, wait... That's souther California~ Ted W ~
What is ZipWall Andy?
It is a highly vapor-impermeable version of OSB intended to be used with tape and without wrap. Seems like a great way to create a wall that cannot dry easily to the outside. It would be at the bottom of my list for sheathing. The roof product might be OK but I would still felt it before roofing.
ZipWall is a Huber product with an integral weather barrier in lieu of housewrap or tarpaper. All you need to do is tape the seams. I don't share Dave's concern about it being highly impermeable. OSB sheathing on its own is essentially a vapor retarder anyway. I'd avoid using an interior vapor retarder with ZipWall, but I do my best to avoid interior vapor retarders, anyway. Because most houses are sheathed with OSB, we regularly build walls that don't dry well to either side. It also depends on your climate. If you're in a hot, humid climate, you want the vapor retarder on the outside anyway. My only concern with ZipWall is that flashing openings relies entirely on the adhesion of the peel and stick.Andy
Thanks for all the help guys.
Help? You'd have to be a genius to come away from here with answers instead being even more confused. <G>Andy
LOL.
We used Greenguard foam boards on the outside of our Tahoe house. The Greenguard gives a bit of insulation and it has built in drainage channels. I don't know about the inspector because the stucco guys put paper over the Greenguard. But the walls are dry even with snow packed against the stucco.
Between the fiberglass and the Tigerfoam in the bays and the Greenguard outside the house is very well insulated and it stays comfortable with the heater barely running.
Eric
Thanks Eric.
I'm trying to wrap my head around this one. It's not easy. Why wouldn't you try to build a wall that dries well? Choosing materials that inhibit this makes no sense.
I'm not saying it's desirable. I'm saying that using OSB sheathing and an interior vapor retarder creates a wall that doesn't dry well to either side. Get a copy of Bill Rose's book, Water in Buildings.Andy
Right... so why recommend ZipWall?
In mixed and hot climates, I don't see a downside. The assumption is that for about half the year in mixed climates, drying takes place inward, and for half the year it takes place outward. As long as you air seal well, and use the highest perm vapor retarder inside as you can, I'd be surprised to see a problem with designing a wall to dry inward. The advantage of ZipWall is that detailing the exterior becomes nearly idiot proof. In my experience, walls are far more likely to have moisture problems related to exterior leaks from faulty installation of flashing around penetrations than because of vapor diffusion from inside. In most cases, vapor diffusion is a pretty minor component, even compared to moisture carried in on air leaks. In the OP's case, he's building in Texas. Most of Texas is a hot climate, so any vapor retarder would go on the outside as a matter of course. In that case, ZipWall seems like a no-brainer.Andy
Dave, let me expand that. I had assumed that Zip Wall had a pretty low perm rating, but that's not the case. Depending on the source, the perm rating of OSB or 1/2 in. plywood sheathing ranges between 3 and .7. It passes less water vapor than tar paper. The published perm rating for the water resistant face of ZipWall is 12 to 16, which is higher than tarpaper and a lot of housewraps, and higher than the underlying OSB. It's hardly what I'd call a vapor barrier. The focus on vapor transmission is a bit of a red herring for most of us anyway. Sure, in the far north the vapor drive may be enough to create trouble. But for the rest of us, the keys to water in framing cavities are controlling air leaks and bulk water intrusion, while allowing for some drying.Andy"Never try to teach a pig to sing. It wastes your time and annoys the pig." Robert A. Heinlein (or maybe Mark Twain)"Get off your dead #### and on your dying feet." Mom"Everything not forbidden is compulsory." T.H. White, The Once and Future King
Edited 3/26/2009 5:10 pm ET by Andy_Engel
Is was reading "Residential Framing" by William P. Spence and noticed that in some areas they put felt between the outside studs and sheathing. Why do they do that?
Not uncommon with old plank sheathing. Helps reduce air infiltration (though not nearly as well as housewrap would).
felt and hardie were meant for each other...
WOW!!! What a Ride!
I thought in Texas they always used tortillas for their wraps.
Corn or Flour? They actually absorb moisture pretty good. LOL.
it's adobe dirt...
WOW!!! What a Ride!
I use felt, but if I were using wrap it would be Typar.
Thanks D.
What David said.
I think I had Typar at Taco Bell.
Awesome.
I've used both. Tyvek¯ etc. is faster; 15# felt is more economical.
Assuming proper installation, both will cut wind infiltration; felt will repel liquid water better.
There may be heat issues with felt in a climate like Texas; possibly the newer synthetics are more resistant to high temps. I don't know about that from personal experience. Hottest I've ever seen it get up here is about 38ºC (99ºF).
I understand that qualifies as a cool spring day down there....
Dinosaur
foolish men call Justice....
99 deg. Nice and cooool. I don't even turn the a/c on till it gets over 100. JK.Thanks for the info.
