Housewrap question
Soultrain | Posted in General Discussion on November 30, 2005 12:34pm
I have my house all wrapped with Tyvek & I’m starting the siding.  In a couple of places, the Tyvek pulled through the nail heads (I thought I’d be okay using button cap nails) leaving holes approximately 1″ in diameter.
Is it sufficient to simply tape over these holes w/ Tyvek tape, or should I cut a slit just above each hole & slide another piece of Tyvek into it & over the hole?a
It’s been pretty windy lately so I expect a few more holes to appear before I’m done.
  1. DanH | Nov 30, 2005 01:20am | #1
    Tape should be fine.
    It's a little curious that you had these holes, though, as we had pieces of Tyvek exposed for months without any tears. I was obsessive about nailing/taping, though.
    happy?
      Soultrain | Nov 30, 2005 03:10am | #2
      I'm suprised too.  The Tyvek has been exposed for approximately 3 weeks.  However, we've had some pretty heavy winds lately.  Not hurricanes by any stretch, but we've had some sustained 35-40 mph winds for a couple of days.
  2. MikeCallahan | Nov 30, 2005 05:28am | #3
    Go over the whole house with tarpaper because tyvek is a fraud and by the time you side it you will blow a million more holes in it that will allow air to infiltrate and negate the whole effort. Tape will do little good.
    Tarpaper self seals and makes a much better barrier for a lot less money. Sorry, The truth hurts.
    I always use 30 lb. felt. There is no better house wrap.
    Mike Callahan, Lake Tahoe, Ca.
      txlandlord | Nov 30, 2005 06:27am | #4
      Interesting point of view. Isn't California the land of fruits and nuts?
    2. experienced | Nov 30, 2005 07:14am | #5
      Mike:
      I assume you don't put insulation in your walls and attic also cuz it'll rot the place out. Single pane windows work well too, no sealed glass to lose the vacuum from!!
    3. blue_eyed_devil | Nov 30, 2005 02:11pm | #6
      Mike, if tarpaper self seals, why do they make us put Ice and Water shield up here under the ice dam areas?
      I'm not knocking tarpaper but it does'nt self seal.
      blue
        Crash | Nov 30, 2005 04:10pm | #7
        I dunno...  I've resided houses that were a hundred years old (no wrap), fourty years old (felt wrapped), and I've never seen any damage or rot caused by moisture, other than from obvious leaks.  I think the whole house wrap issue is a non issue if the siding is installed correctly.  The most important thing to me is properly installing the splines around windows/doors/trim.
          Sailfish | Nov 30, 2005 04:37pm | #8
          I can add that our house was wrapped with felt, and where it was and wasn't eaten by roaches there was water damage, rot, etc.
          I read an independent study (i'll see if I can find it) that put felt against Tyvek.
          The results were failry equal. Tyvek was better in one or two scenarios and the felt led in a couple.
          I had the tyvek on this year during the multiple brushes we had with hurricanes and I tore 3 caps. And those were my fualt for not buttoning up the tyvek properly. I rushed it before the rain hit.
          It also never leaked-----------------------------------------------------------------------------
          WWPD
          1. shearwater | Nov 30, 2005 06:27pm | #9
            Just curious - but why be so obsessive about taping and nail caps for Tyvek when you're going to bang a million new holes in it anyway, once the siding or shingles are applied?  I can see taping all non-horizonal seams, but every nail or staple??
            Soultrain | Nov 30, 2005 07:11pm | #10
            I'm just talking about taping the holes where the button cap nails pulled through.  These aren't little staple holes, but approximately 1" diameter holes.  For now I taped an "X" over the holes & put another nail on either side of the hole (figure 2 nails would be harder to pull through than one.)
            Edited 11/30/2005 11:12 am ET by Soultrain
Mortar for Old Masonry
