This may be a stupid question, but I’m trying to figure out if standard pipe clamps would work with some other jigs I’ve got.
What is the outside diameter of the standard 3/4″ pipe used for pipe clamps?
Thanks.
Thanks.
We found the brightest, best-performing green laser in a head-to-head test of eight popular models.
my cheap but workable calipers say 1-1/16"
thanks!
1"
My dial calipers indicate a variation of .01" between largest and smallest diameter on a stick of USA-made black 3/4" iron pipe. The average diameter is 1.063", just a hair under 1-1/16".
Some of the Chinese product is much less round than the piece I measured.
Bill
Is this a trick question??
Sure sounds like it at first, but it would be the same as asking how big is a 2x4 or how thick is a sheet of 3/4" plywood.
"how thick is a sheet of 3/4" plywood."18MM ?
Thanks all.
That's what I needed to know.Amateurs talk strategy, Generals talk logistics.
23/32" I think.I want my 1/32" back. That's like 3%!!
Edited 12/3/2008 3:41 pm ET by geoffhazel
How about a HENWAY?
or what's a GREEKURN?
I have referred your question to my lawyers, Piecost, Duckworth, & Causewey, Attorneys at Law.They assure me that they will give this matter their undivided attention.AitchKay
Edited 12/3/2008 10:40 pm ET by AitchKay
Sorry that 1/32" went the same place where the missing 1/4 oz of whiskey went when a "fifth" became a 750ml.
The commie metric guys got it.
Plywood is metric now. 1/2 is 12mm 3/4 is 18mm.
I bet that "3/4 pipe" is 27mm or 28mm O/D and 18mm ID. Like it or not the global economy is going to drag us kicking and screaming into a metric world whether we like it or not.
Bye Bye the 2x4, hello 35x80 and too bad if it is a little smaller.
####, it's even worse than I thought.There are 25.4mm/inch so 18/25.4 = .70866 inches (in decimal)Convert that back to 32nds .70866 * 32 = 22.67712So what was 24/32 is now 22 2/3 / 32nds. They ROUND UP to 23. We've lost 1 1/3 32nd/s which is 4% less wood than before, not 3%.Dang.
And how far is The Old Log Inn?
Aitchkay
All the way?
As long as we're on the subject, how long is a while?
A little longer than "a bit", but not as long as "for some time"
Edited 12/3/2008 2:49 pm ET by MikeRyan
ya gona git banned, spit bourbon all over the pix of 'bama i wuz admirigng.
Well I sure as heck ain't gonna go just half way.
It depends upon the definition of the word "is"
