how close can I put my tank?
Stray | Posted in Energy, Heating & Insulation on January 6, 2008 11:13am
Hi All,
I’m making plans to relocate my fuel oil boiler within my own house.  I’m wondering how close I can put my 275gal fuel oil tank to my 141,00btu Weil McClain boiler.
Can it be right next to it?   Would I have to build a rated wall between them?
I don’t have ready access to IRC/NFPA codebook.  Any thoughts and experiences appreciated!
  1. BigBill | Jan 07, 2008 01:33am | #1
    go here and ask your question
    http://www.heatinghelp.com/
    1. Stray | Jan 07, 2008 06:10am | #12
      BigBill,
      I did post on the Wall as you suggested.  Thanks.
      So far, I've gotten responses between 5'-10', less with a rated wall between.  no definitive anser yet, though.  I'll post back here if I get an authoritative answer.
  2. andyfew322 | Jan 07, 2008 03:16am | #2
    I BELIVE it only needs to be a couple feet away, and doesn' tneed any protection
    It takes studs to build a house
    1. joeh | Jan 07, 2008 03:53am | #3
      I believe you best pay attention in school or you'll end up speeling like some of the maroons on BT.
      Joe H
      1. ponytl | Jan 07, 2008 05:46am | #9
        pretty well documented list of that what are considered some of  the brightest minds in history... couldn't spell....  those that point out misspelled words...usually aren't on that list...
        p
        1. joeh | Jan 07, 2008 05:56am | #10
          He's 14, he needs to stick with it. Being able to spell won't hurt him, there's no shortage of those who can't.
          Joe H
    IMERC | Jan 07, 2008 04:14am | #4
    outdoors with it's own containment pit...
    WOW!!! What a Ride!
    1. Stray | Jan 07, 2008 04:47am | #6
      "outdoors with it's own containment pit..."
      I would worry too much about the cold geling the oil.  Negative temps are routine  in my neck of the woods...which is the last time you want to worry about your fuel supply.
        IMERC | Jan 07, 2008 04:59am | #8
        that is where fuel oil and diesel is to kept/stored...
        the rest is yur problem...
        1. Stray | Jan 07, 2008 06:07am | #11
          I'm not quite sure where you live, but in upstate NY, indoor tanks are commonplace.
          Is "outdoor-only" the code in your neck of the woods?
            IMERC | Jan 07, 2008 06:21am | #13
            Mtns of Colorado..
            for diesel and fuel oil it is and varies from county to county......
          2. Pierre1 | Jan 07, 2008 07:19am | #14
            "...varies from county to county..."
            Always amusing to see such variations in basic code requirements. You'd think the laws of physics (vapour and flash points of home heating oil/diesel) varied county to county. ;)
            IMERC | Jan 07, 2008 07:30am | #15
            it's leak/spill containment they're after...
            that's why the containment pit...
            spill fuel indoors and you can find that the building stands a chance of being razed...
  4. sawdust58 | Jan 07, 2008 04:35am | #5
    The inspector in my town in CT says 60" from source of ignition, if closer due to hardship, then 5/8firestop wall
    1. Stray | Jan 07, 2008 04:49am | #7
      Thanks.  That does sound somewhat similar to other things I've heard...
