Hi,
Trying to figure out how to trim around the window. I won’t be tiling all the way up the wall, maybe just stop where it is, I don’t know. All help and suggestions appreciated.
Mike
Understand lumens, ceiling brightness, beam spread, tilt, and color options to make a wise choice on a common fixture that can range from $75 to $750 or more.
I would continue the tile to one full row above the window, and add bullnose tile in the same color.
I'd second the notion of going a course or two above the window then finish with bullnose. It would just be a bit more work,so why not go to the ceiling?
Thanks,
I just wanted a bit of colour between the tile and ceiling.
Mike
Can you find bullnose tile to match that existing stripe?"Put your creed in your deed." Emerson
I'd tile to the ceiling, use another row of green or color of your choice for interest.
