How do I fix water stain on cedar
johndi | Posted in Construction Techniques on February 27, 2008 04:48am
unfinished tongue and groove cedar planking on ceiling  has water stains from a roof leak . Does anyone have any suggestions ? sanding would change surface and would cause the entire ceiling to be sanded .25′ X 15′
Edited 2/26/2008 8:51 pm ET by johndi
  1. andyfew322 | Feb 27, 2008 04:51am | #1
    ".25' X 15'"
    you have a 1/4' ceiling by 15'   ;)
    Ductape can fix EVERYTHING!!!
    1. johndi | Feb 27, 2008 05:01am | #2
      25' x 15' Thanks
  2. GOLDENBOY | Feb 28, 2008 04:03am | #3
    According to Shell Busey, in Vancouver Province, you can wash with 50:50 water and vinegar, scrub with a soft brush and blot dry with a towel.  Continue until all stains are removed. Dry with hot air.
    Who knows.  Good luck.
  3. logcrafter | Feb 28, 2008 04:26am | #4
    the log homestore (wwwLogHomeStore.com )has several products for cleaning logs and decks. might work for ceilings too.
    1. johndi | Feb 28, 2008 05:01am | #6
      I worked on a log home last year . The guys on the job first used house wash and then switched to bleach , I was amazed . It worked great! The logs were pine though, it was very messy and the ceiling was the worst mess.Also I will have to treat entire ceiling .I now have two solid ideas to try .thanks keep em coming
      Edited 2/27/2008 9:02 pm ET by johndi
      1. Bwhite | Feb 28, 2008 06:18am | #7
        I've used a product from my local stain/paint store (Daly's in Seattle) on a piece of antique furniture that was covered in white water marks and it worked perfectly.  Don't recall the name, but it came in a plastic jar but inside it was a little rag, like a tak cloth, but not quite as sticky.
        This cabinet had a finish on it, so I don't know if it's worth pusuing for you, but if you want to try a specialized stain making shop, I'm sure they'll know of the product.
        Good luck.
        Brad
  4. mike_maines | Feb 28, 2008 04:56am | #5
    Something with Oxalic acid should work.  Test it first.  Behr (Home Depot) makes a deck cleaner I've used in a pinch with a variety of acids that took the water stain out of a birch door.
