How do I get this thing open ?????
MBaybut | Posted in General Discussion on November 29, 2009 08:14am
Hi,
I need to replace my pool light so I trying to get to the low voltage cable in the transformer but I can’t find where to open this thing up. I tried the obvious, the top where the lip is but that thing won’t budge, almost looks as if it was tack welded in the corner. Any help appreciated.
Mike
  1. danno7x | Nov 29, 2009 08:19pm | #1
    Looks to me like the top is rusted on. Just beat it, beat it...
    IBEWChuck | Nov 29, 2009 11:50pm | #2
    Since the conduit openings are in the lower portion of the transformer housing, I'll bet that your wiring connections are located there.
    Check out the possibility that the bottom of the can comes off. All of that rust may make the cover seem to be welded on.
    Chuck
    1. DanH | Nov 30, 2009 12:35am | #3
      Yeah, my guess is that the bottom comes off somehow.I can see fasteners or weld marks on both sides about 3" up from the bottom. Can you tell if these are fasteners that come out, or just welds/rivets?
      This country will not be a permanently good place for any of us to live in unless we make it a reasonably good place for all of us to live in.  --Theodore Roosevelt
      1. MBaybut | Nov 30, 2009 05:23am | #4
        Yes, that was it. You can see in pic 3 there's a slot where you can stick a screwdriver in and pries the bottom out. Thanks all.
        Mike
  • Townhouse Transformation
