How do you patch rain gear?
NWCarpenter | Posted in General Discussion on December 17, 2003 06:12am
I have some Helly Hansen rain pants that got snagged by a nail recently and ripped. I’ve tried patching them with duct tape, a Helly Hansen repair kit, rubber cement, and none of it has worked for more than a few hours. It’s raining nonstop and I will have to buy a new pair if I can’t fix them. Any suggestions?
Brian
  1. UncleDunc | Dec 17, 2003 06:36am | #1
    Were they clean when you tried the HH repair kit. My HH raincoat seems to preferentially attract skin oil and gets funky pretty quick.
    Luka | Dec 17, 2003 06:57am | #2
    I patched a raincoat by cutting patches from the unused pants of the same set, and gluing them on with universal PVC glue.
    Live, Love, Forgive and Forget
    quittintime
  3. CombatRescue | Dec 17, 2003 05:16pm | #3
    You can get a piece of the same, or similar material and sew it in - or just sew the hole closed if there is enough fabric.  Then seal the sewing with some seam-sealer made for this purpose (but usually used to seal seams in tents).  You can get seam-sealer at any decent outdoor/camping store.
    HTH,
    Andy
    1. 4Lorn2 | Dec 21, 2003 08:25am | #5
      Some electricians have been known to clean the area around the hole with contact cleaner, only use one approved for plastics, and brush on a few layers of Scotchcoat. If you surround the area with electrical tape before applying the Scotchcoat you can remove it before it hardens and end up with a nice square with a neat edge. I think the rust brown of the coating look good with a commercial yellow coat.
      I have seen a plumber use a piece of shower pan sheeting and the glue used to weld it to make a repair. Don't know if he used a prep compound, cleaner, before gluing.
  4. PhillGiles | Dec 17, 2003 07:20pm | #4
    Get a kit from an "outdoors" store for repairing air mattresses (the good kind, like Rockwater Design, not the kid's item). A decent chandlery have all sorts of water-proof patch kits too.
    In a real pinch, use a kaki patch and seal/glue it on with UHU 'rubber goop' (UHU make a bunch of glues, it's important to get the UHU product labeled "Goop" and specific for patching rubber and able to withstand submersion)
    Phill Giles
    The Unionville Woodwright
    Unionville, Ontario
  5. jystn | Dec 21, 2003 08:51am | #6
    Go to ironworkergear.com They sell fabric cement that works real good.
    1. KenHill3 | Dec 21, 2003 12:30pm | #7
      I discovered an excellent raingear patching material quite by accident. A co-worker jokingly stuck a scrap of roll window flashing to my rainpants. It would not come off without ripping the fabric. I beleive the brand was 'Fortiflash'. Solution found.
      Ken Hill
      Edited 12/21/2003 4:32:13 AM ET by Ken Hill
Old House Air-Sealing Basics
