how do you run conduit in stone walls
canofsoup | Posted in Construction Techniques on December 6, 2010 02:24am
How can electric conduit and outlet, or switches, be installed in stone wall without being noticable?
  1. Scott | Dec 06, 2010 02:44pm | #1
    Is this wall built up with mortar and rock? If so I'd think you could hide conduit in it. I'd use PVC...less prone to corrosion.
    1. [email protected] | Dec 06, 2010 03:03pm | #2
      Yes but it can crak if you have movement.
      True pvc wont corrode.  But it can crack if you have movement in the wall.
  2. JTC1 | Dec 06, 2010 05:57pm | #3
    Conduit and boxes can...
    be installed as the wall is built with relative ease. Just have to be sure to use concrete tight fittings.
    After the wall is completed?
    I have no idea, unless from the other side.
    I would press Scott for more insights.
    Good luck.
    Jim
    1. Scott | Dec 06, 2010 06:38pm | #4
      >>>After the wall is
      No idea either. Jackhammer I suppose, but that's going to make a huge mess.
      I would think about alternatives...like ground burial and receps sticking up out of the ground.
      1. JTC1 | Dec 06, 2010 07:12pm | #5
        Methinks...
        ......that is what the OP is asking.
        As I read the OP's question, granted, the post is not long on details: Wall is completed / existing, now wants to run invisible conduit through it - a retrofit.
        I wish him good luck, but do not have much hope of a favorable outcome.
        You are now talking about ground burial, I'm not so sure this is an exterior wall.
        Jim
  3. semar | Dec 17, 2010 11:25pm | #6
    More info please
    Stone wall on house wall? exterior retaining wall? what is the stone fastened to? Concrete block? Solid concrete, Woodframe construction?
    Inside deco wall?
     Lighting? Electrical wire extension?
