How long can house wrap be left exposed?
newfaner | Posted in Construction Techniques on October 15, 2007 04:31am
Folks here in So. Vt. leave their Tyvek exposed sometimes for years. How long is it effective, how long can I wait to put up the white cedar shingles?
  1. DanH | Oct 15, 2007 05:44am | #1
    It's not good one day and bad the next. It slowly degrades, and the rate of degradation is controlled by sun, rain, wind, and probably two or three other things.
    I forget what Tyvek specs, but I think it's like 60 days. That's probably a good lower limit, but one could go longer if conditions aren't terribly bad. Otherwise there are other brands of wraps that claim to be able to last longer.
  2. DanH | Oct 15, 2007 05:45am | #2
    (But I'd say about 6 months is the upper limit on Tyvek, before it should be ripped off and replaced prior to final siding. It is effective longer as a temporary covering, though.)
    1. FHB Editor
      JFink | Oct 15, 2007 04:39pm | #9
      You can actually just install a new layer of housewrap right over the old one - no need to rip down and replace.Justin Fink - FHB Editorial
      "Everybody wants to know what I’m on...
      What I'm on? I’m on my bike, busting my ### 6 hours a day…
      ...What are you on?"
      - Lance Armstrong
  3. Piffin | Oct 15, 2007 06:21am | #3
    The tannins in cedar degrade Tyvek so tarpaper is the right underlayment for cedar shingles.
    According to some, the tyvek will only last 5-10 years in direct contact with ceda
    1. DanH | Oct 15, 2007 06:34am | #4
      That bit of wisdom has been hotly debated here. IIRC, the Tyvek people don't admit to a problem, and the reports of problems have been spotty.
      1. streets | Oct 15, 2007 07:33am | #5
        DuPont warns in their literature that the "wettability" of Tyvek and building papers can be increased by chemical surface contaminants (surfactants) although it says cedar doesn't contain anything that would do this to Tyvek. Independent testing has shown just the opposite. Typar is less affected and Tyvek is said to be reformulated to reduce this problem. If you are still concerned about it the best solution is to back prime/stain the cedar as recommended by the WRCLA and DuPont or provide an air gap.DuPont says to not allow Tyvek to be exposed to UV rays for more than 120 days. If in doubt about weathered Tyvek, you can send a sample to DuPont to see if it is still usable.
        1. DanH | Oct 15, 2007 01:19pm | #6
          And 121 days later they'll reply.
    2. DougU | Oct 15, 2007 02:12pm | #7
      Piffin
      We are working on a lake house right now that had cedar siding on tyvek. The place was built in 1989 and had cedar dutch lap sidding so there was a full contact between the sidding and the tyvek.
      We tore all the sidding off the place, were giving it a complete face lift, but the tyvek was in about as original condition as possible and I dont have any idea how long the stuff had been exposed to the sun/elements before they got it covered.
      I dont know to much about tyvek, dont use it much in cabinetry anymore! But, I see where it is supposed to go to shid under cedar and in this one instance the tvvek has done OK.
      1. Piffin | Oct 16, 2007 02:48am | #12
        Yeah, I have not seen this myself. Only read it here. There was one account from a guy who said that after ten years when he tore into a wall for an addition or something, the Tyvek was all but gone and in little pieces. I have used backprimned over Tyvek n ddon't lose sleep over it.But I like people to be aware
    Matt | Oct 15, 2007 03:21pm | #8
    I belive the mfg literature says not to expose Tyvek for more than 90 days.  Typar as a better choice for housewrap if it is to be left exposed.
    As far as housewrap degrading under cedar, to me, the judge is still out.  I think it was those U of Mas building science guys who came up with that, but IIRC a lot of their testing is simulated in a lab rather based on actual field rear offs, etc.
    Check out this article: http://www.umass.edu/bmatwt/publications/articles/housewraps_feltpaper_weather_penetration_barriers.html
    Notice the date.  I'm not sure if any new research has been published siince then to support the degradation of house wrap by cedar tannins (sp?).  Anyone got a resource?
    1. streets | Oct 15, 2007 05:26pm | #11
      There would be no reason to expect Tyvek to have deteriorated behind cedar and the sheathing would not have deteriorated unless water penetrated the shingles and the housewrap.I have never seen any evidence that Tyvek is physically damaged by contact with cedar or anything else although cement stucco will adhere to it and staples can tear it. On the whole, it is an amazingly tough material. Certain surfactants (surface contaminants), similar to soap, can reduce the surface tension of water which can allow it to pass through membranes more easily but these chemicals don't necessarily damage the membrane. Spunbonded olefin wraps (Typar after 2003 and Tyvek), and building felts become slightly less waterproof when exposed to surfactants like the oils from cedar. When a virtually waterproof housewrap material leaks slightly it is can be considered significant but since building felt is already far less waterproof than the spunbonded wraps, the reduction is usually ignored. There is a different standard because the materials perform completely differently.The major difference between these WRB materials is that the spunbonded olefin wraps are effectively waterproof, the perforated wraps are less waterproof, and building felt is even less waterproof but becomes highly vapor permeable when it is wet. Most proponents of building felt seem to believe that water that gets behind it can dry to the outside more easily than from behind plastic housewraps. Most proponents of plastic housewraps seem to believe that water will not get behind the wraps if they are properly installed. So, it's a tough call. Probably the best argument for building felt is that it that Tyvek is rarely installed according to DuPont's instructions or even with much common sense. In my experience most carpenters put it up like building felt and prefer it because it is faster and easier to install. Conventional detailing of light wood frame construction has become a nightmare with materials substituted without much attention paid to their different characteristics, compatibilities or interfacing. The future of WRB's will inevitably be liquid applied vapor permeable acrylic membranes that eliminate the space where trapped moisture can cause trouble in insulated wood framing. Huber has introduced their ZIP sheathing and other manufacturers offer liquids that can be rolled or sprayed on in the field over reinforced joints and into openings. It's only a matter of time before the manufacturers of these materials wake up and jump into the house building market. Someday people will laugh when they find that a house was wrapped with the stuff they make large mailing envelopes out of. "What were they thinking?"
  5. FastEddie | Oct 15, 2007 04:54pm | #10
    We had this issue come up on a commercial building and we got a written response from Dupont that the commercial style Tyvek can be left exposed to 9 monts.
  6. northeastvt | Oct 16, 2007 04:24am | #13
    newfaner,
      House wrap is not considered as  "siding" ? :}
    northeastvt(Vermont)
    1. DanH | Oct 16, 2007 04:51am | #14
      Ja, ya'd dink it vas ziding around here. Seen some houses done in the stuff for 3-4 years.
