How Many Shovels to a Cubic Foot
Catskinner | Posted in General Discussion on December 23, 2008 07:11am
What do you think?
Clean concrete sand and crushed stone mix, slightly damp.
Regular old round shovel like on any construction site.
How many shovels of the mix to make a cubic foot?
I don’t know what I ever did with my old measuring box, so I’ll make another this week and post the result. A 2×6 box 17-3/3 inch square (inside) struck level is a cubic foot.
And so is a 94 pound sack of cement.
  1. junkhound | Dec 23, 2008 08:18am | #1
    My square shovel used for throwing reclaim and cement into the mixer is about 4-1/2 shovels full per cu ft.
    Probably a few more for a round shovel.
  2. Piffin | Dec 23, 2008 01:11pm | #2
    5-8 depending how you heap it.
    1. brownbagg | Dec 23, 2008 02:38pm | #3
      9 square shovels. that how many we use making mortar,
      1. MisterT | Dec 23, 2008 06:20pm | #11
        Fastest way to F-up a block wall...let a concrete guy mix the mortar!!!:o).
        "After the laws of Physics, everything else is opinion" -Neil deGrasse Tyson
        If Pasta and Antipasta meet is it the end of the Universe???
  3. john_carroll | Dec 23, 2008 05:13pm | #4
    I don't use a shovelfuls to make mortar--both because my mind wanders as I count off the shovelfuls needed (16-18 per bag) and because a shovelful is an inexact measure. Instead, I fill three drywall buckets with sand and one with mortar.
    Here are some 5-gal. bucket measurements:
    40 five-gallon buckets = 1 cubic yard
    1 five-gallon bucket = .668 cubic ft.
    1.5 five gallon buckets = 1 cubic ft.
    4.5 five gallon buckets = 3 cubic feet (the amount of sand needed to mix one standard bag of mortar).
    1. Catskinner | Dec 23, 2008 05:25pm | #5
      That's some handy info. Thanks.
    2. MikeSmith | Dec 28, 2008 05:17am | #19
      i always work with shovels        pile of aggregate, pile of sand, open bag of cement
      all the shovels are the same....only variance is how many  ( eg....1-3-5 )
      the shovels go straight into the mixerMike Hussein Smith Rhode Island : Design / Build / Repair / Restore
        Sphere | Dec 28, 2008 04:27pm | #20
        "the shovels go straight into the mixer"
        You must buy a lot of shovels.Spheramid Enterprises Architectural Woodworks
        1. MisterT | Dec 28, 2008 06:08pm | #21
          and ear plugs!!.
    3. terranova | Feb 22, 2010 03:50pm | #27
      Mudslinger,
      Duh.
      Found it.
      Thnx.
      J.
  4. BryanSayer | Dec 23, 2008 05:39pm | #6
    Like the old children's joke about how many balls of string does it take to reach the moon.
    Just one if it is big enough.
    1. Catskinner | Dec 23, 2008 05:50pm | #7
      The problem is you are right and I happen to own a few of those kind of shovels. You know, the diesel powered ones. <G>I just want to mix a small amount of concrete for some big post holes. Six or eight years ago I knew this off the top of my head, but I've slept since then so that info is gone.
      1. BryanSayer | Dec 23, 2008 06:02pm | #8
        Dig an extra post-hole, fill it up counting the shovel fulls, viola!
        1. Catskinner | Dec 23, 2008 06:20pm | #10
          I wanna come work for you.We might not get much done, but if we got some government contracts we could make a lot of money, and best of all we'd never stop laughing.
          1. BryanSayer | Dec 24, 2008 09:36pm | #15
            No fair!I actually do work gov't contracts...
      popawheelie | Dec 25, 2008 03:41am | #16
      Or how many makes five. Two in each hand ond one in my mouth.
  5. MisterT | Dec 23, 2008 06:19pm | #9
    Back in Collitch I had a summer job (Summer help, summer not) at the county DOT.
    we would mix and pour a catch basin every morning.
    17 shovels of gravel
    6 shovels of sand
    2 -3 shovels of schment (ONE syllable!!)
    water varied with MC of other ingredients.
    No clue as to how many CF but the ratio should be the same...
    1. Catskinner | Dec 23, 2008 06:27pm | #12
      That actually sounds about right.I do remember that if one is using separate piles of stone, sand, and cement, a 1:2:3 mix is very strong and generates about 3.25 (of whatever units you're using) of concrete.Of course the sand fills in the empty space in the stone, and the cement fills in the empty space in the sand.And Breaktime fills in the empty space in my head when it's snowing. <G>What got me to post the original question is the sand/stone mix I had delivered leaves me with no idea of what the proportions are. So I got thinking about I don't want to waste cement, and I want this strong but not too strong, so what's a good proportion and a good way to figure it out.Usually I figure it out by calling the redi-mix plant. Won't work this time.
      1. MisterT | Dec 23, 2008 06:38pm | #13
        you could: fill up your 1 CF box with the sand stone mix.add H2O till it is saturatedweigh itdry it completely in an ovenweigh againcalculate Volume of water from weight of evaporated water.this is your void space of sand/gravel mixthis will be the optimum amount of schment/water to add to DRY sand/gravel.my guess is it would give a higher strength mix ~4000 psiI am NOT a Mason but I am 1/2 Italian, which is better!!.
        1. Catskinner | Dec 23, 2008 06:44pm | #14
          That's actually pretty good. <G>
          1. peteshlagor | Dec 25, 2008 06:44pm | #17
            Pizza cake.  Ratio of 5 shovels of 60/40 gravel to one shovel of ceement tossed into the mixer.  I don't believe in those diluted down ceement formulas that use 23 shovels to 3 shovels.  That's for municipal workers whom get annual salary increases, retirement, full healthcare, and time off whenever their need scratching.  They get paid to go back and replace the cracked stuff the next year.  Great job security.
          2. Catskinner | Dec 28, 2008 04:55am | #18
            Hey, thanks. 'ppreciate it.
      2. joeh | Feb 22, 2010 05:01pm | #28
        My eyes are gonna fall out, been staring at this screen so long.
        It just keeps coming, Thought I was leaving this stuff in Utah, it's followed me here.
        Joe H
    Mongo | Dec 28, 2008 06:10pm | #22
    With a round shovel, 5 for me.
    1. Catskinner | Dec 28, 2008 06:35pm | #23
      Thanks.I'm setting some steel (W8x48) piles in a not-so-accessible location. The concrete will be carried down the ravine in a skid steer (we think, anyway). It's steep, and way too far to pump.It was 13 degrees outside this morning, and we're supposed to do this on Tuesday. Gonna heat the sand up good and mix in a little Thermalube in hot water, then heat the holes up a bit. Already dropped the sand/gravel on some scrap 8" steel pipe, run the roofing torch down the pipe, wait half an hour, and it's all good.So how rich do you think this stuff needs to be?
        Sphere | Dec 28, 2008 07:51pm | #24
        Hey Cat, what part of this big blue marble do you call home? Sounds like you are north of here?Spheramid Enterprises Architectural Woodworks
        1. Catskinner | Dec 28, 2008 08:15pm | #25
          Northern New Mexico, above 7,000 feet.Similar seasonal climate as Great Barrington, MA, except dryer and more sunshine.
            Sphere | Dec 28, 2008 08:21pm | #26
            Cool..you got the nosebleed seats.
            I think I'm right at about 1000 ft here, I get headaches much higher up(G).  We have similar winter here at 38 N.LAT as we did down in the NC mtns. But there it was 4,110 ft. and that negated the more southern LAT.Spheramid Enterprises Architectural Woodworks
  7. Waters | Mar 03, 2010 07:44pm | #29
    i have such a box.
    a "mongo
    i have such a box.
    a "mongo box" after his insights on concrete mix for counters.
    mine is 3/4 ply and exact 1x1x1 foot.
    i converted shovels to box to 5 gal buckets.
    2 5 gal buckets about 2/3 full is a cubic foot.
    my buckets have marker lines @ quarters.
    shovels never really did it for me...
  8. User avater
    Ted W. | Apr 14, 2010 02:02pm | #30
    I generally don't think about cubic feet when I'm mixing batches, just how many shovels of each ingredient and eye it up as to how much I need at the time. That way it doesn't matter what shovel I use and I don't need a box to measure. I mostly need cu' only for estimating and such. Just my 2c.
