Mostly 1/2 or 3/4 NPT (metal), air and water; I’ve always done 3 wraps. Out of a whole project, would have a few weepers that needed tightening. Recently increased to six wraps; no apparent initial leaks.
Y’all’s experience?
Y’all’s experience?
never leaks
Boy, thank God for BT!
Thanks again.
Forrest - keep painting until the room's too small to get in
glad to help. surprising how that answer can be used in a variety of situations.<g>
Barry E-Remodeler
Depends on what teflon tape, how deep the threads are cut, quality of the threads, etc.........
How tight is tight...........
It's kind of an open ended question with no "real" answer.
I tape then dope, very few leaks.
Too much tape, can hold a test, but then leak during use, cause the gap is too big.
If you think of tape as a lubricant to keep the threads from binding you will have fewer leaks.
If you don't stand behind the troops, why don't you try standing in front of them. Bumper sticker
How in the heck do you get the treads to start with 6 raps?
Edited 5/28/2007 6:11 pm ET by VAVince
I've generally done two, trying to be fairly exact about it (not 2-1/2). Three, maybe, if the threads are yucky looking. I'd agree that with six you couldn't get the threads started.
Had no problem with 6 wraps today. Five new 1/2" x 4" brushed nickel over brass nipples from Lowes; teflon taped both ends; one end into drop-eared brass elbows in the wall, other end into angle stops. Toilet and double-lav vanity - all smooth as silk.
Maybe I'm using cheap thin tape? Not the thick yellow stuff?
Forrest - dry
The yellow is generally for gas.
I have a case of thick pink teflon I like to pull out & see the looks on peoples faces.
Also have some blue that is rated for oxygen.If you don't stand behind the troops, why don't you try standing in front of them. Bumper sticker
Okay, I'll be the one who bites: If yellow is for gas, and blue is for oxy, what's the pink stuff for?
I just use the thin white stuff, wrap it till it breaks and call it good. That's about three or four turns on most days.... <(;o)>
Dinosaur
I have no clue, just found it on the job one day.If you don't stand behind the troops, why don't you try standing in front of them. Bumper sticker
Oh, great! Now I'm gonna dream about wondering what it's for!!
Dinosaur
LOL
So yer not up all night, it's for higher temp lines.
Usually found on medium pressure steam lines.If you don't stand behind the troops, why don't you try standing in front of them. Bumper sticker
Ahhhhhh, the answer to Life, the Universe, and Everything.
Forty-two....
Dinosaur
Thnat's the anwer alrighty, What's the queation?Let's not confuse the issue with facts!
Dinosaur <!----><!---->
May-28 11:38 pm
To:
plumbbill <!----><!---->
(16 of 22)
90412.16 in reply to 90412.15
Ahhhh..... [what's] the answer to Life, the Universe, and Everything.
Forty-two....
Dinosaur
Dinosaur
Will pipe dope and teflon tape work on PVC to PVC like on a pool line to the pump?
"Revolution is not something fixed in ideology, nor is it something fashioned to a particular decade. It is a perpetual process embedded in the human spirit." Abbie Hoffman
Yes, but be real carefull on what brand of dope. Some dopes don't react well with pvc.
Megalok by hercules works well on PVC, put on lightly, & it cleans up with water.If you don't stand behind the troops, why don't you try standing in front of them. Bumper sticker
I'm not sure exactly how I ended up with the stuff, but I use that pink teflon tape quite a bit now- much thicker than the cheapo white tape, two wraps does it every time.
And it matches my handbag, too.zak
"so it goes"
(pssst - we call it a "man purse")Rebuilding my home in Cypress, CA
Also a CRX fanatic!
Parenting has always been a mix of sage life advice and inexcusable laziness.
rector seal t plus
http://www.rectorseal.com/index.php?site_id=1&product_id=213
I wish I knew how to insert an annoying Martha Stewart Banner in my tagline....
Edited 5/28/2007 9:22 pm ET by MisterT
I usually did 3 or 4, but I've reformed. On a recent project but - landscape irrigation, with PVC-to-PVC threads I found the hard way that 3 is too many. 2 or a little more is max. Otherwise it leaks almost every time.
I use hemp ( its actually wool ) almost all the time. It swells when it gets wet and makes an excellent seal.
Only use teflon for plastic on plastic joints and use as many wraps as looks right. However many that might be........
Not an exponent of the DILLIGAF system.
From an old thread:
Only read this if you have insomnia:
Originally PTFE tape was made in both a single density and double density type. The single density type was typically made in 1/2" x 520" rolls and commonly distributed in all hardware stores.
Double density PTFE tape was made in 1/2", 3/4" & 1" widths and typically distributed through the Plumbing, HVAC and Mill Supply stores but rarely found in the hardware.
Many jurisdictions adopted the double density tape as the standard for sealing threads on natural gas lines. Later, in an effort to insure the double density tape was being used the industry began making the double density in a yellow color to distinguish it from its single density counterpart.
Recently the ASTM(American Society of Testing & materials) and ANSI(American National Standards Institute) adopted new standards for PTFE tape and instituted a color coding system to identify the different grades.
White..Single Density -for NPT threads =/3/8" but =/ 3/8" but =/
Copper..PTFE tape containing copper granules,,used as a thread lubricant but may not be used as a thread sealer.
PTFE tape is only approved when the proper type is matched to the size of the joint and when three full wraps are applied under tension and wrapped in the direction of the thread.
While Teflon tape is commonly used by the homeowner and some tradesmen for all thread joints it is best to only use it on "Non-permanent" joints, such as attaching the shower arm, an angle stop or other joints that will require periodically changing out.
PIPE DOPE is the preferred thread sealant for permanent joints, such as threaded water lines or gas lines, but you must be careful when selecting pipe dope. You must read the labels carefully and be sure the product you select is specifically labelled as suitable for the application that you intend to use it for.
In the hardware stores we commonly find either the Gray pipe dope or the white "teflon" pipe dope. The white teflon pipe dope has a small advantage because it contains teflon granules that work as a thread lubricant which aids in making tight joints.
Most tradesmen rely upon Rectorseal which is a nearly universal pipe thread dope which is listed for Potable water, Non-potable water, Steam, Natural Gas, Propane, Gasoline, High pressure Air, Nitrogen, Hydrogen, and most industrial gasses & chemicals.
While RectorSeal is difficult to find in the hardware or big box stores it can be commonly found in any Plumbing, HVAC or Electrical supply house in sizes ranging from a 4oz can to a gallon bucket.
Rector seal is made in both a hardening and non-hardening formula. The hardening type is most commonly used on steam piping while the non-hardening type would be most suitable for the typical residential application. The non-hardening type also has the advantage that it will not dry up and get hard in storage.
Mongo
Wow!
Thanks for the interesting read. Sounds like I should go back to RectorSeal!
It's just so darn goopy -
And it smells bad
It's also alot of fun when you step on an errent tube and track it.Rebuilding my home in Cypress, CA
Also a CRX fanatic!
