how much block???
loucarabasi | Posted in General Discussion on June 11, 2007 12:47pm
How many 8 inch blocks are in a skid?
Thanks, Lou
  1. calvin | Jun 11, 2007 01:32pm | #1
    View Image View Image
    The figures shown below are intended for “rule of thumb” use only.
    Unit Quantities
    • 2 1/2 High Block (21/4x8x16)–3.10 block per SF of wall area
    • Half High Block (4x8x16)–2.25 block per SF of wall area
    • Standard Block (4”, 8”, 10”, 12”)–1.125 block per SF of wall area
    • Face Brick Modular–7.0 brick per SF of wall area
    • Oversize Brick–6.0 brick per SF of wall area
    • Utility Brick–3.0 brick per SF of wall area
    Mortar Quantities
    • Block–3 bags per 100 block
    • Face Brick Modular–7 bags per 1000 brick
      Oversized Brick–8 bags per 1000 brick
    • Utility brick–10 bags per 1000 brick
    Sand Quantities
    • Sand–1 CY per 7 bags mortar
    Horizontal Wall Reinforcing Quantities
    • Horizontal Wall Reinforcing–SF/1.33
    Cavity Fill Insulation Quantities
    • Cavity Fill Insulation–4 CF per bag
    Approximate Volume Required To Fill Core Voids In Block
    • 6x8x16 2 core 0.17 CF/block
    • 8x8x16 2 core 0.25 CF/block
    • 10x8x16 2 core 0.33 CF/block
    • 12x8x16 2 core 0.39 CF/block
    Approximate Quantities Of Concrete Required To Fill Bond Beams
    • 6x8x16 BBL 0.173 CF concrete per LF
    • 8x8x16 BBL 0.22 CF concrete per LF
    • 8x8x16 DEEP BBL 0.46 CF concrete per LF
    • 12x8x16 BBL 0.37 CF concrete per LF
    • 12x8x16 DEEP BBL 0.74 CF concrete per LF
    Number Of Blocks Per Cube
    Size
    Arch PSF
    No Per Cube
    Arch PSMF
    No Per Cube
    Arch GF
    No Per Cube
    21/4x4x16
    270
    4x4x16
    240
    240
    288
    4x8x16
    120
    120
    144
    6x4x16
    100
    100
    120
    8x8x16
    75
    75
    90
    12x8x16
    50
    50
    60
    Typical Concrete Masonry Unit Dimensions
    Nominal
    Actual Unit Size
    Faceshell
    Thickness( a)
    Web
    Thickness (a)
    Inch-
    Pound
    Metric
    Inch-
    Pound
    Metric
    Inch-
    Pound
    Metric
    Inch-
    Pound
    Metric
    (in.)
    (mm)
    (in.)
    (mm)
    (in.)
    (mm)
    (in.)
    (mm)
    4x8x16
    102x203x406
    35/8x75/8x155/8
    92x194x397
    3/4
    19
    3/4
    19
    6x8x16
    152x203x406
    55/8x75/8x155/8
    143x194x397
    1
    25
    1
    25
    8x8x16
    203x203x406
    75/8x75/8x155/8
    194x194x397
    11/4
    32
    1
    25
    10x8x16
    254x203x406
    95/8x75/8x155/8
    244x194x397
    13/8
    35
    11/8
    29
    12x8x16
    305x203x406
    115/8x75/8x155/8
    295x194x397
    11/2
    38
    11/8
    29
    (a) Dimensions are minimum required by ASTM C 90 (a) (ref,3).
    Designing Walls To Avoid Cutting Units On Jobs
    Rule 1. A dimension in even number of feet (2 ft., 4 ft., 6 ft., etc.) will always work out in full-and half-block.
    Rule 2. A dimension in an even number of feet plus 8 in. (2 ft. 8 in., 4 ft. 8 in., 6 ft. 8 in., etc.) will always work out in full-and half-block.
    Rule 3. A dimension in an odd number of feet (1 ft., 3 ft., 5 ft., etc.). will not end in full-and half-block. But an odd number of feet plus 4 in. (1 ft. 4 in., 3 ft. 4 in., 5 ft. 4 in., etc.) will always work out in full-and half-block.
    Examples of wrong and right planning of concrete masonry wall openings
    View Image View ImageView ImageView ImageView ImageView ImageView Image
    View Image View Image View Image View Image View Image View Image View Image View Image View Image View Image
    http://www.quittintime.com/
