rearl
| Posted in Construction Techniques on
I am using [these](https://www.menards.com/main/hardware/fasteners-connectors/construction-hardware/column-post-bases-caps/mitek-reg-4-x-6-triple-zinc-2-sided-post-anchor/pa46e-tz/p-1444445516725-c-8825.htm?searchTermToProduct=2271751) pier/footing to post brackets to attach my deck posts to my footings.
My footings are plumb but not completely level. When I put my posts into the brackets and go to plumb them, how “not flat” can they sit on the bracket when making them plumb and not have to worry?
I am aware I can use an angle grinder to grind the concrete level but I don’t know how close to level I would even need to grind it for this to be within a “plumb-able range”.
Thanks!
Listeners write in about ambitious projects and sinking patios before asking questions about old house specialists, attic headroom, and home shops.
Get some nonshrink grout to install the mounting brackets level. The nonshrink grout acts as a pad/ filler that you set the bracket in, level, while it's wet. When it dries, it does not shrink (hence the name) and your bracket will remain level.
Frankie
